Generation IV External Engine - comp cams trunion upgrade kit
View Full Version : comp cams trunion upgrade kit
Double J
07-21-2012, 09:54 PM
Can anyone advise what special tools are needed to install these other than standard sockets and wrenches? Also where can I get the correct torque numbers for bolts on rocker arms and valve covers? Thanks in advance!
stereojnky
07-21-2012, 11:13 PM
There's a couple of YouTube videos on the exact procedure and tools needed.
mallder
07-22-2012, 08:26 AM
I used a brass drift to knock out the old bearngs and used my bench vice to press in the new ones. They come with spacers to make it easy. Very simple.
Sales3@Texas-Speed
07-23-2012, 09:25 AM
There are instructions provided with the kit, it takes most guys about 30-40 minutes to install the upgrade. Very simple!
1989GTA
07-23-2012, 12:34 PM
Is there a lift or spring pressure limit when exceeded one should consider upgrading their lifters? Example 400# spring pressure or around .600" lift.
victorf
07-23-2012, 01:30 PM
FSM has the torque. 22 ft/lbs for the rocker bolt and 106 in/lbs for the valve cover.
Best follow the CompCams's video, the other long 11 minutes Ytube video is dangerous, he punched out oem trunion with punch and hammer, then bangs rockers on metal table. His actions looks macho and might look good on TV but clearly, he lacks fineness. His actions indicates that he has no understanding that metal can get distorted when bang around! Never a good idea to bang internal engine components!
Keep in mind, to remove or install trunions, one needs to keep the process inline and perpendicular to avoid distortion. I made my .900 base and .005 drift as recommended by CompCams and used the combinations on my mill. But a drill press will do just fine. I'd found the stock bearings tighter during removal and the new trunion bearing reinstall not so much!
Take your time, its not how fast a person can do it, we are dealing with fitting precision bearings - remember "haste makes waste"!
Good luck!
Double J
07-23-2012, 07:47 PM
Thanks to all! Good 411
RezinTexas
07-24-2012, 06:30 PM
I used a bench-mounted screw vise and taped aluminum strips on the jaws to avoid gouging the rocker arms. It was quick, easy, and didn't have any issues.
victorf
07-25-2012, 02:29 PM
We can all justify with whatever used for the install - most choose alternatives due to lack of resource!
Keep in mind, the truer it is inline and perpendicular, the less variables we have to deal with and ends up with less complications down the line!
LFSADRG
07-25-2012, 02:32 PM
Summit has the proper tools to get this done
http://www.summitracing.com/parts/SME-906011/
http://static.summitracing.com/global/images/prod/large/SME-906011.jpg
Jontall
07-27-2012, 08:38 AM
Be very careful not to over-stretch the snap rings and check each one for cracks/fractures after it's installed.
Sales3@Texas-Speed
07-27-2012, 11:49 AM
We have a tool similar to LFSADRG's picture, but on my personal vehicles I have used a bench vise or a small arbor press.
victorf
07-27-2012, 01:55 PM
You ever notice how the acme thread on a vise draws on the jaws.
I would not consider a bench vise over a arbor press with its rack and pinion!
Even though my machinist bench vise is a high priced Wilton!
RezinTexas
07-28-2012, 08:32 AM
i chose the horizontal screw vise over my vertical hydraulic press because of the finer control and feedback I get with the handle. this way I could ensure each bearing went in with the same resistance and there were no issues.
victorf
07-28-2012, 02:02 PM
Using any sized hydraulic press is like using .50 caliber to kill a chicken in this case!
If vise is chosen for the feel, only the precision milling vise offers any sort of parallelism! But the short fall with precision milling vise is the movable portion of the jaw, it is designed to pull work down during the final lock down, which is outstanding for its intended design for secure work hold down! But if this type of vise is used as bearing press and you don't need to lock down, it should be more then sufficient to provide true in line closing and ensure perpendicularity for the bearing fit into the rocker's bore.
Normal bench vise has only acme thread - the good one that is. It doesn't have the machined, fitted, grounded and mated surface to slide on as the milling vise!
Sales3@Texas-Speed
07-30-2012, 11:40 AM
Oddly enough, I bought my arbor press just for doing trunion upgrades! Its simple, gives me total control (or at least a better feel of it), and is consistent.
LongIsland63SS409
07-30-2012, 01:11 PM
How did the trunion upgrade work out for you?
Mike
victorf
07-30-2012, 01:36 PM
At Texas-Speed, your company doesn't have a simple drill press? Arbor press is great, but an drill press can do that plus many other duties!
I don't have a business nor a drill press! But I do have a mill and a lathe! I did my trunion upgrade with the mill but I can also do it with the lathe. But the mill is infinitely easier since I don't have to balance the parts other than centering it. Out of the two, mill is my favorite. Besides milling, I used it to compress recycle cans, breaking bead off motorcycle tires and such, terrific mechanical advantage.
00BlackSS
07-30-2012, 01:56 PM
he said he has the arbor press for his own personal use. my guess its at his house. haha
Posted from LS1Tech.com App for Android
victorf
07-30-2012, 02:43 PM
He did not specify was for his own personal use, but he did say "just for doing trunion upgrades".
I did not want to make assumptions, but its all good!
-TheBandit-
07-30-2012, 04:20 PM
LOL
Are you trying to give him a hard time for using the right tools to do a job? Sure a mill or drill press could be used for light press duty, but if you have the right tool available, why not use it?
I have a small arbor press at home. How much force is required to do this?
1989GTA
07-30-2012, 04:39 PM
"if you have the right tool available, why not use it?"
Exactly.
RezinTexas
07-31-2012, 05:48 AM
it should be noted that the Comp Cams trunnion bearing instruction manual does not specify the type of press to be used.
smokeshow72
07-31-2012, 05:58 AM
Very little force is required for this installation; I used a quite small arbor press while installing mine and had no issues at all. Short money, easy installation with the included tools (plus a deep socket or other random piece hanging around your cellar).
C
Sales3@Texas-Speed
07-31-2012, 10:23 AM
I bought my arbor press for personal use. Although, I can assure you that Texas Speed does have a drill press!
victorf
07-31-2012, 02:21 PM
Right on Jake!
No disrespect intended, just discussing about the tools used, as others are on subject and made clear their view with tool/technique choice! I always hope to learn something from discussions or hope I have contributed something also.
Naturally, we have to make do with whatever our resource and experience!
I hope I have not come across as giving you or anyone a hard time!
