New LS1 Owners - Newbie Tech - better and quieter pulleys??
View Full Version : better and quieter pulleys??
14k
07-21-2012, 11:15 PM
is there such a thing for replacement? iv got a squeal that sounds like a bad pulley but cant find the culprit. iv changed the tensioner pulley removed the ac belt put a long screwdriver to each pulley and none sound bad. while im messing with the pulleys i thought there might be better and quieter pulleys out there.
TheBlueKnight
07-21-2012, 11:38 PM
Have you changed the main belt? I know I was chasing a squeak under the hood for a while before I decided to just change the whole main belt and the squeak vanished.
14k
07-21-2012, 11:42 PM
recently, no. i changed it around November last year when i got a new water pump. ill take it off and see if the squeak goes away.
but is there a chance there might be quieter pulleys? when i had my magnaflow exhaust i could hear the belt spinning (no sqeak just spinning) over the exhaust.
TheBlueKnight
07-22-2012, 12:08 AM
Someone else will have to chime in there, I've never heard of any pullies being advertised as quiter before.
sjsingle1
07-22-2012, 12:09 AM
goodyear gator back......THE quieter belt
dalejrfan88
07-22-2012, 09:46 PM
That squeal could be the belt slipping. Ive had a few on my truck like that. Over time i guess they stretch and start to slip causing a horrible squealing noise. +1 on the goodyear gatorback belts, they are the only belt i will buy now.
14k
07-22-2012, 10:01 PM
I doubt the belt stretched in less than 2k miles. Could have tho. I'm just going to pull the alt and idler to regrease them. Only 2 pulleys I haven't messed with other than wd40 on them.
mike.warrenws6
07-27-2012, 10:36 PM
belt squealing is caused by bad idler, bad tensioner (puller/whole thing causing belt to slip), power steering puller, alternator pulley. your a/c pulley isnt gonna squeel. if it goes bad it will lock up and you will know it
14k
07-28-2012, 06:49 PM
I'm leaning towards my alt. it's a rebuilt autozone one and it has chirped in the cold since I got it went away now I think it's coming back 24/7 now.
garygnu
07-28-2012, 06:58 PM
how many miles on your motor ?with high miles the balancer grooves can wear causing a bigger gap where the belt meets the pulley.
14k
07-28-2012, 09:10 PM
Not sure PO put a 98 in it. Not documentation just junkyard writing everywhere. Carfax was clear
