autotap, look at IAC counts or desired IAC counts??
hey guys, i'm kindof new to autotap so bare with me.
been trying to get all the bugs worked out after the head swap. i have never checked my IAC's before. my question, is do i want to look at the IAC or the desired IAC? when i look at IAC's it just reads flat 0, all the time. when i look at desired IAC's it reads from 90-100. so, what does this mean? what should i be looking at here?
thanks
thanks
ok, thanks bomax.
i have searched through the archives and saw that the windows version of autotap 2.04 does not support the actual IAC parameter. is this correct? this is the version i have and that would make more sense as to what is happening. i was very careful when installing everything (intake and all the vacume lines) and i have not set a code for having IAC's at 0. does it sound like my version of autotap dosn't read actual IAC's? if it dosn't, should i just look at my desired IAC's to get the counts where i want them?
thanks in advance
thanks in advance
