Wiring harness clean-up ?'s
Old 07-22-2012, 10:46 AM
3DFORMULA's Avatar
Default Wiring harness clean-up ?'s
I'm stripping the cars harness down some as I have removed the hvac/box, radio, air bags, power doors. I have a '94 manual online and it ain't the easiest to use with this process. I have removed all the radio and speaker wiring from the rear. What I did was completely unwrap the harness of the tape, and pull the wires back to the starting point, then cut. So I do have a ?. Is there anything I should be careful of as I continue this procedure with the 22 wires coming out of the drivers door and passenger door? Is there anything to NOT just pull from the hvac plugs, air bag plugs?
Thanks
Quick Reply: Wiring harness clean-up ?'s
