LS4 Performance - Problem with cylinder 1 spark plug.. keeps going bad!
jstevanus
07-22-2012, 10:50 AM
My first problem was a rough idle, got the cylinder 1 misfire code from Autozone, did my research here, and replaced the spark plug. The problem was solved. Then, less than a year later, I had the same problem, and solved it by replacing the plug again! Why does this keep happening? I've asked a few car guys I know, and they had no idea. Does anyone have a suggestion or three? Any help is greatly appreciated.
Edit: Edit: I found a post HERE (http://www.automotiveforums.com/t1070365-discuss2008_gp_gxp_oil_fouled_spark_plug_twice_.ht ml)where they are blaming the oil consumption issue. They say oil in the cylinder is destroying the plug. I've read that GM now has a solution for the oil consumption issue, but how much is the fix? I have no warranty.
lVloses
07-22-2012, 10:54 AM
If DoD is active than that is most likely your culprit.
jstevanus
07-22-2012, 11:02 AM
What is the cheapest way to get the DoD turned off? Are most mechanics able to do this easily?
Brian396
07-22-2012, 11:28 AM
Cheapest find someone with HPtuners, $100 for credits + what ever they wanta charge?
Easiest Lew tune, and arguably the best way to go.
jstevanus
07-22-2012, 11:31 AM
Thanks! And extra thanks for the quick reply! I'll look into that for sure. Will that help with the oil consumption too?
Brian396
07-22-2012, 11:48 AM
I do believe 9 out 10 dod delete cures it.
ryanisl33t
07-22-2012, 02:39 PM
Turning off DOD will help cure majority of the oil consumption. And I just did what Brian mentioned to have mine turned off, found someone with HPtuners to turn it off, just have to shell out a little dinero for credits.
straitchev
07-22-2012, 04:24 PM
I had this problem and did an overkill tune and probably went away. AND....the motor doesnt burn oil anymore. MPG is the same as it was before the tune.
jstevanus
07-23-2012, 06:50 AM
Thanks everyone for all the help! I just remembered hearing there's a guy at work, who also has a GXP, that tunes it with his laptop. I'm going to track him down and see if he will disable the DoD for me.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
