ignition problem
Old 07-22-2012, 02:00 PM
99reddevilFRC's Avatar
Default ignition problem
just bought a used 02 camaro with stock ls1. car starts sometimes but most of the time it dont turn over. the security light has been on since i got it. pulled starter and had it checked and its fine. replace ignition? replace key and ignition? anyone with any help it would be appreciated.
Old 07-22-2012, 02:24 PM
k_cash1432's Avatar
Try this to jumper out the anti theft
go up behind the Glove Box on the right side, there is a Relay with a big Yellow Wire going in, Purple Wire coming out. I had to connect them two to make it work on my car..that is the Anti-Theft Relay that is also part of the Neutral Safety circuit.
Old 07-22-2012, 02:33 PM
thank you ill try it
Old 07-22-2012, 02:44 PM
is it a cluster of 6 big wires?
Old 07-22-2012, 06:57 PM
k_cash1432's Avatar
No its a relay just unhook the relay and jumper the two bigger wires in the relay.
