Tools & Fabrication - DIY Ramps how to
View Full Version : DIY Ramps how to
charchri4
07-22-2012, 03:46 PM
My ramps are awesome DIY ramps and if you have a lowered car with wide tires these are a must have especially to do alignments.
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/2.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/3.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/31-1.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/11.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/111.jpg
The tops of the bases are 11" wide by 20" long and raise the car 9". The bottom part of them are 11" wide by 24" long. Mine are nearly all wood I had lying around and you can do the math to figure out that is a lot of feet of 2x4s!
The risers or actual ramp part is 54" long and the tops of them are 2x10s. The reason for the little hunk of 2x6 at the top is because a 10 foot 2x10 was quiet a bit cheaper then a 12" 2x10 so I just added on to it. The boards under the deck are 2x4s laid on their side. Using them alone raises the car 5".
Everything is screwed together with LOTS of 2 1/2" sheet rock screws.
They are very stable and I feel really comfortable under them. If you want to add a safety feature you could put a little tab down on the riser to lock it into the base. Or you could go up from the base into the riser. I was planning on doing that but never did. I've used these for years and never had one move.
The dents you see in the top of them are from using them as jack stands. Often when I have it up on the ramps and pull a wheel I just kick the ramp under the car and set it on it. It's the perfect height to sit right on the jacking point of the car or under the K member. I should patient these puppies!
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/95.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/94.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/96.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/97.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/98.jpg
By the way the trick to getting the risers cut exactly right is put the tops up on a 2x4 and scribe a line on your riser boards like so:
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/99.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/1065.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/100.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/101.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/102.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/103.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/104.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/105.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/106.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/107.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/108.jpg
For little stuff or oil changes I use just the riser part which is the main reason I never put the tab in them that would lock them to the deck.
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/109.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/110.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/112.jpg
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/113.jpg
2nasty
07-22-2012, 06:11 PM
What are those 2 chunks of wood on the back side of the risers for support? Measurements please? And would you make them longer?
Also whats the measurement of the piece that sits under the risers on the base?
bad_408_vert
07-22-2012, 08:02 PM
sorry to be off topic , but, are your fog lights stock?
got milk??
07-22-2012, 08:03 PM
Looking good, paint them and I bet they last forever!
Conrad
07-22-2012, 08:13 PM
These are cool, saw them in another thread of yours. I will probably make something like this. Do you think the ramps could be steeper without being longer? I would want more of a lift.
98camarols1
07-22-2012, 09:00 PM
i just builded me set today..used some of your idea.lol
charchri4
07-26-2012, 04:29 PM
I put those little 2x2s in there about a year after I made the ramps for a little extra lateral support. Mostly for when I am just using the risers as ramps. You wouldn't really need them if you put enough screws in the top.
No I wouldn't make them any longer. They are plenty long and a nice gradual incline to put the car up on.
charchri4
07-26-2012, 08:12 PM
Yeah I think you could go up one more level with the same length easy. That would give you 10.5" of lift but I have never thought it necessary except once. When I put my headers in I had the car up on the ramps then jacked it up another 4.5" from there with blocks on the ramps. For the last 3 Camaros and last half dozen years these have worked fine at 9"
charchri4
07-26-2012, 08:15 PM
The little lights on the outside are stock. I think they are part of the SS package? If you are talking about the 2 shiny things right in the center by the license plate those are brake duct inlets not lights.
http://ls1tech.com/forums/suspension-brakes/1572847-diy-brake-ducts-less-then-20-bucks.html#post16605601
Doug G
07-29-2012, 07:32 PM
Nice build... only thing I'd add is better lateral support than only those 2 little blocks on the ramps.
ghettocruiser
08-03-2012, 12:22 PM
I like this design! Mine are 2x10s sandwiched on top of each other getting shorter and shorter as you go up. Then I also built a stand of all 2x10 to use if I need to go in under the side or get the trans out.
BUT...mine are EXTREMELY heavy. After a day of working, they are a bear to move around or store. Yours not only look lighter, but being two pieces would make them easier to stash too.
I might re-vamp my ramps and go with this idea. Been wanting to make a new set that are more user friendly. Plus I can steal some 2x10s from my ramps, and 2x4s are cheap enough.
Thanks!
J.
zacht
08-03-2012, 01:04 PM
Thanks!
J.
mine are like this!!! i share your thoughts...they are heavy as hell...
Darth Cypher
08-08-2012, 04:58 PM
My Rhino ramps are shit and want something that has a lower angle and is wider. Like what I see here. I might incorporate some of these ideas into my plans. One question I have is what type of wood do you buy from the store? I don't have a saw or anything so I will have to have it cut there and then bring the pieces home to put together.
charchri4
08-09-2012, 12:13 PM
They are lighter for sure then planks and easier to store in pieces but the best thing is being able to get rid of that riser for easy access.
charchri4
08-09-2012, 12:30 PM
All of what you see there I had lying around except the riser tops. The only reason they are 11" wide is because I had a pile of 2x4s that were cut to 90" and I could get 8 cross bars out of each one.
If think I was going to start from scratch I would probably use a 2x6 on edge for the center 2 layers rather then so many layers of 2x4s. But to answer your question this is all just basic framing lumber that any lumber yard could cut down for you. Just draw out what you want to do on paper and figure out how many of each length you will need. The lumber yard in my little town (pop. 1200) doesn't charge for cuts but I bet places like home depot does so you better watch that.
The other thing you might do is go talk to your local high school wood shop teacher. If he is like the one in my town he is always looking for easy projects like this and you would might be able to get these made for the cost of the wood.
Good luck!
VETTEX2
08-10-2012, 03:29 AM
Rhino's are onlym 40 bucks and they are lighter
charchri4
08-10-2012, 06:49 AM
:huh: Sure I really enjoy piling up the shims to get lower cars on and working around the risers that are totally in the way to do anything like SFCs or a clutch. I wouldn't trade you if mine cost twice that.
leon phelps
08-16-2012, 03:25 PM
nice post. Fred and Lamont would be proud.
btlegacy
08-17-2012, 10:38 AM
That is very ingenious. Nice job!
VETTEX2
08-23-2012, 03:15 AM
My car is lowered and rolls right up.
I use my lift for big jobs , you out'a try one
I wouldn't trade any tools I own , ever.
Of course i don't go for ghetto solutions.:swing:
charchri4
08-24-2012, 12:19 PM
Thanks! I appreciate you taking the time to contribute to the discussion.
VETTEX2
09-10-2012, 05:22 AM
Your Welcome.
dabest09
10-21-2012, 01:21 PM
Bringing back an oldish thread. Do you have any pictures of the clearance of the back bumper when the car is raised up all the way on the tallest ramps? I'm worried my trans am bumper is gonna drag the ground.
charchri4
10-21-2012, 06:11 PM
I'm sorry I don't and the car is put away for the year. There is about 2 inches to the pipes and 4 to the bumper I would guess. That orange floor jack you see in my alignment thread just fits under the back of the car with it up but just barely.
http://i1114.photobucket.com/albums/k534/charchri4/DIY%20Alignment/16.jpg
Here is the alignment thread
http://ls1tech.com/forums/suspension-brakes/1565421-diy-poor-mans-wheel-alignment.html
Jerm__
11-01-2012, 08:10 PM
Nice, I made my own also!
Pony Exp.305
11-07-2012, 06:41 AM
Nice write diy
