General Maintenance & Repairs - Headlight motor problem again
rxrom
07-22-2012, 07:58 PM
When I turn on the lights on my 2000 trans am the driversid light goes up the just falls back down. I'm trying to figure out why this is happening. I noticed that there is a plastic stop missing that stops the arm that's connected to the motor. Or is it something else.
Thanks
Roman
wssix99
07-23-2012, 05:17 AM
Is the actuating arm hitting the metal stop that the plastic went on? How long has it been since you last worked on the motor?
rxrom
07-23-2012, 11:13 AM
This is a different trans am. I never did anything to this motor (have only owned it for 2 years). The arm misses the metal tab. It seems loose. I tightened all the bolts but still loose.
wssix99
07-23-2012, 11:30 AM
The arm is keyed to the square edges of the motor shaft. You'll have to wiggle it a bit before it will slide down on the shaft securely. Sometimes, just tightening the bolt won't be enough to get it pressed on the shaft if its not lined up correctly.
Once its on the shaft and pressed down, it should be fine.
You might also check the angle of the stop tab and make sure it matches the other side of the car. I had the same thing happen to me and once the arm started going by the tab, it had leverage on the very end and bent it a little.
Here's a good tip for replacing the plastic bumpers that you are missing: http://ls1tech.com/forums/general-maintenance-repairs/1482213-looking-firebird-headlight-door-actuator-bumpers.html
rxrom
07-23-2012, 02:42 PM
Thank you very much. I'll be making a new stopper and checking alignment over the weekend.
rxrom
08-01-2012, 07:25 AM
Back yard mechanic way I fixed the arm from missing the metal stop tab. Took an three prong to two prong cord converter (for electrical cords that have the ground but the house autlet that has no hole for ground). Ripped out the metal prongs. Slight trim with utility knife. The larger hole is perfect snug fit. Costs 0.50 cents.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
