View Full Version : Drag Bags for a V1
den_99_GTX
07-23-2012, 12:40 PM
Does anyone have a PN and a website for a 05 V1?
itsslow98
07-23-2012, 12:51 PM
I would contact air lift directly to see what will fit the application.
skydiver
07-23-2012, 02:28 PM
Bags I bought were airlift 80753, seemed just a little short but worked, got that number from a post on cadillac forums back in 08 I think
But like itsslow98 says , might not be a bad idea to check with airlift to see what they show
den_99_GTX
07-23-2012, 02:39 PM
Thanks!
ChitownLS1
07-24-2012, 12:49 AM
Did the bags help with the wheel hop?
skydiver
07-24-2012, 05:25 AM
Aready had the 9" in for some time when I added the air bags , Was adding them trying to resolve traction issues.."....... So I can't answer that one , didn't have a wheel hop problem?
For the cost of the bags I think I'd give it a try on the wheel hop issue . Been aprox 3 years since I put them on , but it seems like they were about $120 for the kit with air lines,Ect .
den_99_GTX
07-24-2012, 07:34 AM
Did it help with traction? Is your rear coils the same as a regular V?
skydiver
07-24-2012, 03:47 PM
Have KW shocks & adjustable springs , Make that "had" because when I added the air bags I had to go back with stock springs because the kW spring are to small diameter for any air bags I could find
So to make a longer story shorter ......... Yes they are stock springs but have been cut down some & they retain the kw spring height adjuster
And yes they have helped with traction by experimenting with different pressures on each side
Dragman
07-28-2012, 10:17 AM
I here some people put a football in spring then air up! Never tried though.
den_99_GTX
07-31-2012, 10:47 AM
That sounds like a good idea.
den_99_GTX
07-31-2012, 10:48 AM
I just ordered a set of bags from Air Lift:PN# 60724 3in dia x 7in tall.
NEED MO POWA!
07-31-2012, 11:23 AM
Cool im interested to see your results and some installed pics. I assume you are installing these on stock springs right?
den_99_GTX
07-31-2012, 12:03 PM
I have the ground control setup.
NEED MO POWA!
07-31-2012, 12:15 PM
oh ok still interested in your results
den_99_GTX
08-02-2012, 12:13 PM
I just got the bags yesterday and will be installing them tonight.
I am also putting on a set of MT drag radials 305/35/18. FYI, I don't have any wheel hop issues, just traction. I will also get some pics.
den_99_GTX
08-02-2012, 09:06 PM
I got the 305's on without any visual rubbing....(I didn't take it for a test drive yet) and no spacers. I also installed the drag bags and mounted the air valves on the rear trunk scuff plate. It's late and I didn't want to wake the neighbors for a test drive. I did take some pics before my phone died and will upload them tomorrow.
NEED MO POWA!
08-02-2012, 10:57 PM
pics man, pics!!! what wheels u running those 305's on?
den_99_GTX
08-03-2012, 06:51 AM
Work computer has me blocked from uploading pics.
My wheels are the accessory wheels widen to 10in. PM a cell # and I can send you some pics from my phone.
