longcut
07-23-2012, 06:37 PM
Where can I learn the ins and outs of combustion chambers? When to use Flat tops, dished and domed pistons? Whats considered high and low ratios and what is too of a compression?
My6speedZ
07-23-2012, 07:16 PM
Oh lawd, haha.
Dynamic VS Static compression (this has alot to do with octane):
http://www.yellowbullet.com/forum/showthread.php?t=472656
More DCR info:
http://www.empirenet.com/pkelley2/DynamicCR.html
It Is important to understand that DCR is not the be all end all in determining weather your engine will run on pump gas it just helps more than static because your taking into affect the valve events. VE, Attitude, temperature, and the tuner have alot to do with making sure your car will run on pump gas.
Combustion Chamber sizing (in relations to piston shape):
http://www.yellowbullet.com/forum/showthread.php?t=461895
Search, Search, Search and Search. There is so much good technical information out there not just on this site but others that it will keep you busy for years if your interested in learning it. There is enough practical experience and sponsors that do enough of this stuff to where you can get ideas for a strong running combination without to much back breaking research and calculating, if you find yourself getting lost in a swirl of information.
longcut
07-23-2012, 07:22 PM
oh my gawd, thats some good links. Ill be reading for a while ty
