Johnny@Xtreme_Trans
07-24-2012, 02:42 PM
Xtreme Performance Transmissions Sale
2 Year Warranty on all our transmission and converter combos
No Transmission Core Needed
LS7 Clutch Kit (clutch, pressure plate and flywheel) - $425
4L60E Level 2 Transmission $1495 or $2130 with Billet Converter +Free Shipping
• Hardened pump rings
• Servo D ring kit instead of Teflon
• New Accumulator Pistons
• Modified Pump Assembly
• Oversized Boost Valve
• High Quality Overhaul Kit, Frictions and Bushings
• Xtreme Transmissions Shift kit
• Borg Warner dual cage 29 element Input Sprag• Corvette 2nd gear Servo kit
• Wide rear sun gear bushing
• Heavy duty sun gear shell “The Beast”
• High energy 2-4 Band
• High Energy 7 friction clutch pack with full thickness Kolene Steels
• Teflon Pump Bushing and Extension Housing Bushing
• Built with Performance Tolerances and Lube Modifications
4L60E/4L65E/4L70E Level 3 Transmission $1895 or $2525 with Billet Converter +Free Shipping
• New electronics
• 4th gear billet servo kit
• Billet 2nd gear Servo kit
• Upgraded Bearing Type Reaction Carrier Shaft
• Wide 2-4 Band with Reinforced Anchor
• New 4L65E 5 Pinion OEM Front and Rear Planetary Set
• High Energy 8 friction clutch pack with full thickness Kolene Steels
• Input drum Steel sleeve prevents input drum breakage at spline area
• 2-3 Shift Valve Upgrade
4L60E/4L65E/4L70E Level 4 Transmission $2595 or $3225 with Billet Converter +Free Shipping
• New electronics
• 300m Input Shaft
• 300m Output Shaft
4L80E Level 2 Transmission $2395 Or $3150 with Billet Converter +Free Shipping
• 4L80-E up to 800HP
• Completely Rebuild with Quality Rebuild kit
• High-energy Performance frictions
• Bonded pistons
• 34 element intermediate sprag
• Xtreme Transmissions shift kit
• New solenoids
• New OEM Filter
• New sprags
• New Trans-go Spacer plate
• New speed sensors
• 6 Direct frictions instead of 5
• HD Int. Snap Ring
• Billet Forward Hub
• No core needed
4L80E Level 3 Transmission $2800 Or $3500 with Billet Converter +Free Shipping
4L80-E up to 1000HP
Bonded pistons
New solenoids
New OEM Filter
New sprags
New speed sensors
HD Int. Snap Ring
Billet Forward Hub
300M Input Shaft
300M Intermediate Shaft
No core needed
TH400 Street/Strip Transmission $875 or $1150 with High Stall Converter +Free Shipping
6L80E and 6L90E Performance Rebuild -- CALL
TH400 Race Transmission with Trans-Brake $1425+ free shipping
Race frictions
300m input shaft
billet steel hub
pro-tree rev. pattern transbrake
billet snap ring ring retainer
deep aluminum pan
LS7 Clutch Kit = $425+shipping
6L80E Billet Converter any stall (2800-4000) $755+Free Shipping
4L60E Billet Converter any stall (2800-4000) $695+Free Shipping
4L60E Deep Cast Aluminum Pan $135
TH400 Deep Cast Aluminum Pan $95
4L60E 300M Input Shaft $339
4L60E 300M Output Shaft $445
4L80E 300M Input Shaft $320
LS1 OEM Flexplate $55
LT1 OEM Flexplate $49
• New electronics
• New electronics
• 300m Input Shaft
• 300m Output Shaft
• Bonded pistons
• New solenoids
• New OEM Filter
• New sprags
• New speed sensors
• HD Int. Snap Ring
• No core needed
4L80-E up to 1000HP
Bonded pistons
New solenoids
New OEM Filter
New sprags
New speed sensors
HD Int. Snap Ring
Billet Forward Hub
300M Input Shaft
No core needed
Race frictions
300m input shaft
billet steel hub
deep aluminum pan
