JacksonWs6
07-24-2012, 03:38 PM
My ws6 has an e-cut out welded in and wired up. But there is no switch on the end of the wire. The cut out functions when I hook my booster pack up to it, but it is becoming a pain to open and close. Does anyone know what switch I can use, or if there is one that will plug into the existing end?
TyCZ28
07-24-2012, 04:09 PM
http://www.amazon.com/SWITCH1-Electric-Cutout-Replacement-Toggle/dp/B003R2RTES
QTP Toggle Switch. that should be the one you need... if you have 2 of the plugs you took a picture of you will need the (QTP Switch2)
JacksonWs6
07-24-2012, 06:13 PM
There is only that wire running from the cut out to under the seat. Does that switch run to the battery then?
TyCZ28
07-24-2012, 06:45 PM
ok thats the style you need then for a single QTP cutout.. the red wire runs to a power source..
