Trickflow 215's and MS3
Old 07-24-2012, 07:10 PM
JIMS SVT's Avatar
Default Trickflow 215's and MS3
Thinking of doing some trickflow 215cc heads on my stock shortblock with the MS3 cam.The heads are 59cc chambers. Will I be 'ok' with the ptv clearance? What head gaskets?
Old 07-24-2012, 07:36 PM
djfury05's Avatar
Or you can save money and do this with no PTV worries if you don't have the MS3 already.. https://ls1tech.com/forums/parts-cla...cator-cam.html
Old 07-24-2012, 07:40 PM
JIMS SVT's Avatar
MS3 is in the car already with the stock heads.
Old 07-24-2012, 10:06 PM
garygnu's Avatar
maybe look at a vengeance racing head/cam combo.TEA has a great cam for trick flows heads also.
Old 07-25-2012, 02:33 AM
JIMS SVT's Avatar
Changing the cam is not a option
Old 07-25-2012, 03:36 AM
intenseblue's Avatar
Will NOT clear.
Old 07-25-2012, 09:48 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
That will not clear! You will need less cam, or a different head with more valve drop!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-25-2012, 09:59 AM
LS1Tech Sponsor
TrickFlowTech's Avatar
It is not going to clear with the heads being milled.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 07-25-2012, 10:36 AM
JIMS SVT's Avatar
Which head should I be looking for then?
Old 07-25-2012, 10:38 AM
Captain Double Post
BOBS99SS's Avatar
Look at tsp prc heads, they can set you up with something that will work very well, and there killer heads,
Old 07-25-2012, 10:39 AM
ss454327's Avatar
Why does it have to be 59cc chambers?
Old 07-25-2012, 10:40 AM
We have numerous heads that will work. Our ported GM casting Stage 1 LS6, Stage 2.5 LS6, and Stage 2.5 5.3L heads all work when setup for that cam. Also we can setup the PRC 215's and 227's to clear. Of course the TrickFlow 215's will clear it if they have not been milled as well!
We offer all of the heads I've mentioned at competitive pricing and would be happy to help!
__________________
Old 07-25-2012, 10:46 AM
wytry's Avatar
Not that I recommend it...but my RapTR cam (236/242 .615 .615 111 LSA) cleared 215's w/ 59cc chambers.
Old 07-25-2012, 10:51 AM
JIMS SVT's Avatar
Pretty sure that cam is bigger than the MS3 also.
What was your minimum pistons to valve clearance?
__________________
Old 07-25-2012, 10:52 AM
It is very close when it comes to piston to valve clearance.
__________________
Old 07-25-2012, 10:54 AM
JIMS SVT's Avatar
We have numerous heads that will work. Our ported GM casting Stage 1 LS6, Stage 2.5 LS6, and Stage 2.5 5.3L heads . !
Do you have the 5.3 heads in stock currently? Last time I emailed you guys you didnt have any or know if ya was goning to get any. Id like to get the most compression/power from a set of heads without flycutting with the ms3. What head would I be lookin at there?
Old 07-25-2012, 10:56 AM
I do have a couple sets of the 5.3L heads setup for the MS3 in stock currently!
__________________
Old 07-25-2012, 04:14 PM
PREDATOR-Z's Avatar
What makes you think that 5.3s have smaller chambers than TFS 215? Aren't the 215s 64cc??Not to mention the 5.3s can't hold a candle next to the 215s
Old 07-25-2012, 05:09 PM
tillery's Avatar
Funny. The TFs 220s clear in my engine. I better not say anything to it or it may change the game. Yrs milled and a .040 gasket. Sorry. MS3 on a 113.
Quick Reply: Trickflow 215's and MS3
