Gears & Axles - almost back on the road, one last question
bigti99a
07-24-2012, 08:38 PM
so i almost have the rear done. i have the new carrier and now i cant get off the stock 3.42s off the damn grenaded one. i tried everything i could throw at the bitch. so i have a friend with some stock gears in good shape. not sure if they are 3.42 or 3.23. i have a 6 speed car. will lowering the ratio with 3.23 hurt me at all, if so where. is it even possible? i have basically just a little above stock power and DD my car. thanks.
therabidweasel
07-24-2012, 11:08 PM
You remember that the ring gear bolts are reverse thread? ...said the guy who broke all 10 of his lol.
I wouldn't want shorter gears than stock, but I guess they'd do.
SS SLP2
07-24-2012, 11:49 PM
Yes going from 3.43 to 3.23 will make a bit of a differance, but if you did not know about the change you will not notice it, yep you may find the bolts unscrew easy if you try the other way.
try this
http://www.wallaceracing.com/Calculators.htm
Johnny
bigti99a
07-25-2012, 07:45 AM
i am pretty sure they where getting turned the right way. i'll double check it.
bigti99a
07-25-2012, 08:57 AM
got another ring gear. the old one is like seized up on the carier, when it let go i think it swelled or something and locked that bitch on there.
thanks for that link there is a lot of helpful stuff in there.
FirstYrLS1Z
07-25-2012, 05:10 PM
"got another ring gear"
sounds like from the way it's worded that you're gonna replace the ring gear only and not the pinion gear. Ring and pinions are matched sets from the gear manufacturer.
Ring gear to carrier fit is typically a slight interference fit. With the ring gear bolts loose but threaded in a few turns,hitting/tapping the bolt heads will 'walk' the ring gear off the carrier.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
