Gears & Axles - ABS ring for a 10 bolt
jman54002
07-25-2012, 01:24 PM
will the stock ABS ring fit on an after market center section for a 10 bolt?
planning on getting a truetrack center and need the ABS to work. can I just press the old one off then press it on the new center?
Nemesis350
07-25-2012, 01:45 PM
You should be able to, but hopefully someone that has done it on an aftermarket diff can chime in for you. Be forewarned, it's a pain in the $#@ing ass to get that abs ring back on, just in case it seems impossible while you do it lol
Ethan[ws6]
07-26-2012, 07:31 AM
you can buy the differential with the reluctor ring all ready on it. Just bought a truetrac for a 12 bolt that had one. That'll be your best bet.
jman54002
07-31-2012, 01:47 PM
UPDATE...no you cannot buy the center with a ABS ring on it...But yes the Factory unit does fit on the after market unit. Tap it on and off. thanks for the reply's.
therabidweasel
07-31-2012, 07:39 PM
Please search Google for the word differential and then search for center section. They are different things, the ring goes on the diff.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
