front drag tire/spacers/lugs
Old 07-25-2012, 03:51 PM
Jadedbird's Avatar
Default front drag tire/spacers/lugs
couple questions
what brand/size front tire do you guys run at the strip?
what spacers do you use up front?
is there a write up on how to grind your brakes? (i found one on a jank site... lacked in detail and no pictures)
also what lugs do i need for prostars?
and last where did you buy all this stuff? summit? jegs? tsp?
Old 07-26-2012, 10:47 PM
coolmanvette75's Avatar
I run 15x4.5 weld drag lites with goodyear bias ply tires. No grinding and a 5/16 spacer, but I'm on LT1 brakes. I used open end m12 shanks from summit
Old 07-27-2012, 08:37 AM
Jadedbird's Avatar
well i know the rears will need grinding on prostars..
but like i said. i cant frind a good write up
Old 07-27-2012, 08:57 AM
roninsonic's Avatar
I use 1.75BS 15x3.5 Jegs Sport Mags with 26x7.5x15 M/T Sportsmans and cheap Autozone open-ended tapered seat lugs, and I didn't have to grind or use a spacer.
Old 07-27-2012, 09:22 AM
Jadedbird's Avatar
hmm i saw those last night at autozone and wondered if they would work
Old 07-27-2012, 11:18 AM
Jadedbird's Avatar
https://ls1tech.com/forums/drag-raci...s-101-a-3.html
found it... im questioning the safety of grinding calipers
