New LS1 Owners - Newbie Tech - what should i do first a ms3 cam or fast 102mm intake
lq96.0
07-25-2012, 06:37 PM
what should i do first? which one will make more hp? which would be more expensive? and what else would i have to upgrade when putting in these new parts? 01 z28 lq9 6.0 ls6 intake longtube headers. automatic
98camarosixo
07-25-2012, 07:00 PM
I have lq9 and had ls6 intake. I wuld definitely out can first no doubt
baalic
07-25-2012, 07:07 PM
I would go cam first..... The 102 may be too much without the cam.. And the cam should garner better hp per $
98camarosixo
07-25-2012, 07:08 PM
Sorry I ment I would definitely. Do the cam. Swap
baalic
07-25-2012, 07:16 PM
:) to be honest, i would do a stall before cam since your auto, ms3 without it is gona suck a little...
On that note.... Post 1000!!!!!!!!!!
jarheadtex
CAM...all day
lq96.0
07-25-2012, 07:33 PM
What else would I have to get if I get the ms3 cam
AsEpSiS
07-25-2012, 07:40 PM
what?
baalic
07-25-2012, 07:46 PM
Valve springs, lifters, tune... Where to start.
lq96.0
07-25-2012, 08:45 PM
What if I get a cam that is not as powerfull like the
Texas Speed 228R 228/228 .588"/.588" would I still have to get a lot of other parts the car is my daily driverdumdumdumdumdum
bernarlitt
07-25-2012, 09:04 PM
No matter which cam you choose you'll still basically need the same parts. ex: Valve springs, retainers, locks, push rods etc......
I8UR4RD
07-25-2012, 09:10 PM
the 228r is a badass cam. id take it over the ms3 anyday. it will surprise you. either way, as mentioned you have to strengthen up the valvetrain or you could do some damage. calls texas speed and just get the kit with the .650 springs or .700's and it should run close to $700 for it all including pushrods too. you can do the install yourself, and id strongly advise that you swap to an ls2 timing chain while in there. youll make around 400-410 rwhp im guessing. run low 7's with a good 1.6 60 foot and a stall (the stall will make it alot faster) , but yet again, without a stall its going to try to push you through red lights and stop signs. it gets aggrivating to have to stand on the brakes all the time. you can give PTC a call, or buy my damn near new 3200 10'' inch race converter from them that I had with my 228r. it was $500 new, I'll take $400. so all in all, if you install it all yourself, your looking at about 1100-1200 dollars plus a tune. if someones installing it for you id expect anywhere from 1650-$2100 installed and tuned. depends on how big a crook you find to do the work.
usmcpi
07-26-2012, 12:35 AM
You can't run the MS3 with the stock stall. But id start with stall and gears first. Then go cam. Then heads. Then intake.
Bugsy
07-26-2012, 01:36 AM
Do a stall before anything else. You'll be glad you did!
bww3588
07-26-2012, 02:12 AM
I agree. Stall and gears first. You'll have to get your tune tweakdd a little for shift points and such. However, wait to do the intake the same time you do the cam. You will save money in the long run by not having to pay for a tune twice.
BOBS99SS
07-26-2012, 06:09 AM
Long story short, big cams are not a budget way of going fast, max effort cams require max effort parts,fast intake/at least 4.10 gears/1 7/8th headers/a good dual exhaust/chris1313 etc, ms3 is a good cam but i would do more research 90% of people that go with a big cam wish they would have gotten something smaller, imo i would go with something in the low 230range, if your after the sound you can get a big cam sound on a much smaller profile
BOBS99SS
07-26-2012, 06:10 AM
With that said, i would do a stall first,run a ls6 intake for awhile untill you can get some of the main parts, then when you have it running good go for the fast
lq96.0
07-26-2012, 02:39 PM
What stall and gears should I get. I'm new to all this stuff.
NC98Z
07-26-2012, 02:55 PM
Now you have to descide if your gonna spray or not. If you are then something onn the order of a SS3600-4000 Yank. If your not then a PT4000 like I'm running. If you are gonna run 26" tires get the 3.73 gears. If your running a 28 " tire then a 4.11. Yukon make the quietest gears I've ever had installed.
clonedws6
07-26-2012, 03:04 PM
Had tons of people and even this same guy telling me all this bull before I bought my cam as well. Blah Blah Blah big cams suck yatta yatta. I love mine and the way it made my car run. Low 12s in a gto with cam and bolt ons, winning.
Im pretty sure 98% of this dudes posts are hating on big cams. They all say the same stuff too lol
Kingc8r
07-26-2012, 03:50 PM
As others have said get a stall and gears first.
If going with the ms3 get a 4000 stall. I have a SS3600 and with 3.73s I'm not impressed at all
1BadBlkB1tch
07-29-2012, 03:36 PM
with ms3 youll need 3400+ stall for your auto just to warn you do intake first if you dont have a stall
garygnu
07-30-2012, 08:00 PM
look at a EPS cam ,newer lobe designs.the same power with a little less duration.
My6speedZ
07-30-2012, 08:19 PM
I have a donkey dick cam and before I got my gears I hated it. It came in the long block I got a good deal on (thus i had not planned on swapping gears as 4.10's in a 10-bolt with a manual is just a waste of money) and if I would have been buying heads and a cam to put on myself instead of getting the whole motor I wouldn't have gotten a cam this big.
My car can actually make it run pretty good and it pulls like crazy up top but the power doesn't come on fully until 4000 rpm.
OP the 228 with a mid sized stall and some 3.73 gears will be a nice combo. If you want something bigger stay in the low to mid 230's IMO. Only get a huge cam if your chasing dyno numbers, or are planning to mod your car around the cam to make it run/drive respectably.
Garygnu brings up a good point too, I am a huge fan of the results I have seen from the EPS 226/234 cam. Lots of people with nice heads putting down really respectable numbers out of a 346 with better torque than I am putting down.
