Low Coolant light ????
Old 04-03-2004, 05:59 PM
Brewski4u1's Avatar
Default Low Coolant light ????
so my low Coolant light will not go off i have tried everything its driving me nutz i filled it to the point where it overflowed but still the light stays on so then i was liek just maybe it was b/c some other fulid was low!! getting desprate i checked everything all full !! STILL on does anybody have any idea what to do about it other then pulling the bulb!!
Old 04-03-2004, 06:21 PM
XtinctHawk02's Avatar
I would disconnect your battery and see if the computer reset's it.
Old 04-03-2004, 07:25 PM
DANSLS1GTO's Avatar
I'd check the owner's manual and see what all the 'Low coolant' light staying on could mean.
Dan
Old 04-03-2004, 10:39 PM
Brewski4u1's Avatar
i've tried both and the ligfht keeps coming on!! i think the sensor is all F*** uped or something
Old 04-04-2004, 12:45 AM
SMOKIN01TA's Avatar
it is, just cut the wire under the dash or keep replacing it every once in a while. mine never went off, i didnt car though on my old car. that seamed to be problem with the 98's and 99's
Old 04-04-2004, 10:04 AM
WILWAXU's Avatar
'00 & up cars don't have that sensor
Try filling up the reservoir, then try wiggling the sensor... If that doesn't work, replace the sensor.
Old 04-04-2004, 10:08 AM
T/A-Speedfreak's Avatar
You can also just disconnect the sensor.
Old 04-04-2004, 12:09 PM
SMOKIN01TA's Avatar
