LTX parts 4 sale
LTX parts 4 sale
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): TX
Item Condition: Used
Engine: LT1/LT4, Small Block
LS Engine?: Non-LS Part
LTX PARTS
- BMR a/c delete plate $90
- 2000 Camaro SS M6 radiator $60
- Comp cams 7608 pushrods lt1 $75
- Taylor lt1 8mm spark plug wires $40
- 4th Gen front suspension steering components - L & R spindles, 2 wheel hubs, 2 ABS speed sensors, 2 harness, 2 high temp blue painted calipers, 4 thermoquiet brake pads, L & R drilled and slotted brake disc rotors. $125
- 93-97 f-body Eurolamps sealed beam conversion headlight kit, 4352 high beam lamp assembly with xenon bulbs L & R (Works with HID kits) $50
- 93-97 f-body Euro lights sealed beam conversion headlight kit, 4351 low beam lamp assembly with xenon bulbs (Works with HID kits) $50
- Holley 512-502-1 Adjustable Fuel Pressure Regulator LT1 LT4 Red $80
- 1993 1997 LT1 LT4 Aluminum Fuel Injection Rails with cross over tubes $40
- 93 - 97 Fourth Gen FBody LT1/4 Edelbrock strut tower brace with mounting brackets black $75
- 4TH GEN F-BODY RADIATOR IN WORKING NO LEAKS FACTORY RADIATOR $50
- MSD IGNITION 8680 ADJUSTABLE SPARK TIMING CONTROLER UP TO 15 DEGREES ON THE FLY $120
- PLX M-300 AIR / FUEL RATIO WIDE BAND O2 MONITORING SYSTEM BRAND NEW KIT, MODULE UNIT WITH WIDE BAND O2 SENSOR AND HARNESS $275
- SBC VORTEC ENGINE PRO GEAR DRIVE TIMING SET WITH HIGH SPEED BUSHING TIMING GEAR $50
- SBC LT1 INTERNAL BALANCE 3 BOLT FLEX PLATE OR FACTORY OIL PAN $25
- LT1 POWERBOND HARMONIC BALANCER CRANK DRIVE PULLEY $25
- NEW PUSH RODS MANLEY 25735 CHROME MOLY 5/16 7.400 PUSHRODS 0.080 WALL $95
- NEW PUSH RODS MANLEY 25732 CHROME MOLY 5/16 7.375 PUSHRODS 0.080 WALL $95
- NEW MOROSO 62510 SOLID MOTOR MOUNTS BRAND NEW IN ORIGINAL PACKAGE NEVER USED $25
- 1993 - 1997 LT-1 INTAKE MANIFOLD 58MM TB PORTS AND 195cc MATCHED INTAKE RUNNERS $50
- L98 LT1 TPI CORVETTE CAMARO IMPALA - AIR FOIL $20
Thanks
98-02 ls1 coil packs with harness and bracket $150
u still got these im just accumulating parts. i have coils already but need brackets and harness. are these good coils i can buy yours and sell my coils. would you take any less.
i can send payapl right now.
I bought the headers and oryis from the Super chevy swap meet at the drag street in baytown. The guy said they were stainless worx? Ran them on my car about 3 months before it got rearended. . Just fyi shipping is right at $60:
