12 Second Club - So close to 11's!
Blwn_by_Twins
07-26-2012, 07:33 AM
Well before last night the fastest I'd had the car was 13.1. Before I loaded it on the trailer last night I'd clicked off several low 12 passes ending with a best of 12.1@113. 1.74 60'. I was hoping for mid 12's, so even though I left with an issue, I'm very happy. I even lifted the tires on a couple of passes. :guns:
98 T/A M6 w/ lid, ls6 intake, 1 7/8 lt's, & Magnaflow exhaust were the only power adders. Put to the ground through A TDP trans, Monster clutch, and a MWC 9"
Buddies have videos, so I'll post them as I get them.
This was the first pass of the night. 12.6@111 1.9 60'
http://i266.photobucket.com/albums/ii264/GSXR-John/Lucifer/th_IMG_8201.jpg (http://s266.photobucket.com/albums/ii264/GSXR-John/Lucifer/?action=view¤t=IMG_8201.mp4)
LFSADRG
07-26-2012, 12:52 PM
Thats moving for such few power mods. Good job.
WeakSauce6
07-27-2012, 07:03 AM
12.3 pass
http://www.youtube.com/watch?v=92g4_2W35E8&feature=plcp
12.1 pass
http://www.youtube.com/watch?v=ofl2c6pM5ww&feature=plcp
moge11
07-27-2012, 02:12 PM
GETTIN IT!!!! Good Job Bro! 1.6x 60' and you'll be in the 11's.. Is your car Tuned???
LS1rob00
07-27-2012, 03:11 PM
Nice!! That's ideal. What was the DA and how much does the car weigh?
moge11
07-27-2012, 03:15 PM
What gear are you running? and what what was the 1/8 ET & MPH???
Blwn_by_Twins
07-28-2012, 09:10 AM
Partially, by myself.
DA 1448. I'd guess weight to be around 3500 somewhere, but not sure.
3.89 gear; 7.8@89.5
moge11
07-28-2012, 03:21 PM
Thats movin! Straight GETTIN IT! good shiftin too dude. seems not too many people can drive worth a damn and wonder why they are stuck in the 13's
sabersaw30
07-28-2012, 10:32 PM
You deffinately got the mph for 11s. You got you a strong car for the mods you got.Looks like you are trying to come out to hard.Try to come out a little easier and see what happens.looks like its bogging off the clutch.
moge11
07-29-2012, 09:44 AM
Where do you have the 2-step set at???
WeakSauce6
07-29-2012, 12:16 PM
6300rpm tires at 21psi.
TheBlueKnight
07-31-2012, 10:55 AM
Very nice man, stout car for sure!
98z-28redcamaro
07-31-2012, 06:49 PM
car definitely bogged off the line....track was prepped awesome.....
lt1 sport
08-05-2012, 11:12 PM
What is your MWC rear adjusted at, I will be going to the track soon with mine. I've got my control arms in the lowest hole and my torque arm (Long Version) second from the top with a -1 pinion angle. My car is basically same mods as you but with 4.10s, I couldnt do anything better than a 2.2 60ft on stock suspension hoping to do much better.
white99ta!!
08-06-2012, 03:18 AM
if you leave at a higher rpm you should have it. Seems like your car bogs to much off the line
Blwn_by_Twins
08-06-2012, 01:50 PM
I have my control arms second hole from the bottom. The rest of the setup is the same as yours except I have Strange adjustables all around. Start @ 21 psi hot and if you hook there go up a few lbs. My first pass that night at 15psi and 4500 on the 2 step got me a 1.9 60'.
murphinator
08-07-2012, 06:09 PM
you list nitrous outlet in your sig , but your trap doesnt look like a sprayed trap....
good job on the et drop from your last trip:cheers:
Blwn_by_Twins
08-07-2012, 06:36 PM
I did but on only on the last couple of passes. Had traction issues on the first pass (2.2 60') and 2nd pass developed a loud tick. All the listed times were NA at 21* of timing.
badazz81z28
08-07-2012, 09:05 PM
At first I was going to call BS with those times w/ little mods...I didnt see you are spraying! lol..
Blwn_by_Twins
08-07-2012, 09:25 PM
To clarify, I made 9 passes with out Nitrous @ 21 deg of timing. These 9 passes net'd me a best time of 12.1@113. I then made 2 nitrous passes and neither was clean and resulted in bad times.
12.1@113 was done on motor....without nitrous.
Blwn_by_Twins
08-07-2012, 09:27 PM
Just realized I didn't put the cam in the description on mods. Also had a 221/221 cam.
moge11
08-08-2012, 04:37 AM
welllll in that case...... :nutkick:
Mike Morris
08-09-2012, 10:19 AM
Nice!
