228/230 @ .05 with .571/.573 (54-428-11) comp cam
Old 07-27-2012, 01:10 PM
ejbta2's Avatar
Default 228/230 @ .05 with .571/.573 (54-428-11) comp cam
Is any one running this cam and what is your opinion ? I ran 12.28@ 109 with boltons and a ss4000 yank with 3.73 gears. And just added the (54-428-11) comp cam. Are you pleased with the cam it has a 112 lsa. Waiting on my tune by frost.
Old 07-28-2012, 11:21 AM
ejbta2's Avatar
Can I get some feed back?
Old 07-28-2012, 12:14 PM
Fbodyjunkie06's Avatar
I think you will really like this cam in your car.
It's a good mid size cam that will still make great low end torque and also still pull to 6400 easily and make power up top like a larger cam would.
It should also sound nice and lumpy at idle with the 112+4.
Old 07-28-2012, 03:55 PM
ejbta2's Avatar
Thanks for reply I am having trouble with the new 5.0 6 speeds I pull them 6 car lengths out of the hole but only beat them by almost 1 car but the autos only run in the 12.8 and the 6 speeds trap 115 they really pull 1/8 to 1/4
Old 07-28-2012, 04:02 PM
ejbta2's Avatar
Thanks for reply I am having trouble with the new 5.0 6 speeds I pull them 6 car lengths out of the hole but only beat them by almost 1 car but the autos only run in the 12.8 and the 6 speeds trap 115 they really pull 1/8 to 1/4 they pull hard up top I bought the cam so I can run with them on the hyway get my tune from frost Mon or Tues ,we will see
Old 07-29-2012, 03:19 PM
oange ss's Avatar
I used that cam N/A, good mid range to 6500 rpms, without too much loss on the low end...really comes alive after 3,000 rpms...will defintiely help
Old 07-29-2012, 07:32 PM
redtail2426's Avatar
thats the cam i have,check my sig,made 440 rwhp and trap 119 full weight
Old 07-29-2012, 09:52 PM
I think you will be happy with it.
Old 08-07-2012, 05:48 AM
ejbta2's Avatar
Thanks for the replys. I get my tune back from frost on 8-8-12 or 8-9-12 can't wait I wii post results of track time improvements. It might be a few weeks, a little break in time.
Old 08-07-2012, 08:22 AM
oange ss's Avatar
Originally Posted by redtail2426
thats the cam i have....made 440 rwhp...
holy ***** !! through a 9" ?
Old 08-17-2012, 02:29 PM
ejbta2's Avatar
Got tune back and ran good for 87 miles and lost rod bearing # 3 am searching for short block.
Old 08-18-2012, 05:54 AM
Naw that was through the ten bolt,im curious what it is now with the 9".
Old 08-18-2012, 10:15 AM
bairdsauto's Avatar
How did it idle and drive with the frost mail order tune. Thanks bairdsauto
Old 09-20-2012, 11:33 PM
ejbta2's Avatar
Just got motor together idles good (lopes) need to break in then take to track got a short block from Thompson motor sports. I can't wait to really get on it.
Old 09-21-2012, 07:25 AM
smg267's Avatar
Running the same cam with PRC 5.3's, UDP, ported fast 90/90', 85 MAF, slp long tubes, slp dual dual, ls7 clutch and put down 425/400. The car drives like it is stock less occasional rpm drop issues. Have no idea what it runs but your times are great!!!
Old 09-26-2012, 12:40 AM
ejbta2's Avatar
My times are with out the cam,I am hoping for 11.5 to 11.7 when I get motor broke in.I dynoed 323. And ran the 12.28.with the cam I hope to dyno 380 to 400.
Quick Reply: 228/230 @ .05 with .571/.573 (54-428-11) comp cam
