Fueling & Injection - Need help with finding pin-out for #1 injector.
The Alchemist
07-27-2012, 02:41 PM
I'm hooking up my Aquamist meoh/water injection and it runs on injector duty cycle, so I need to tap the signal and ground wire for the #1 injector. I'd prefer to do it at the pcm, so does anyone have a chart or location guide to the pin-outs for the PCM in a 2000 f-body?
I'd hate to have to undo all of the wiring harnesses to trace it back.
Thanks.
The Alchemist
07-27-2012, 03:13 PM
Ok, thanks to this link:
http://www.lt1swap.com/2001_PCM_CONN_PINOUT.htm
I know that it's #36 on the blue harness for the signal wire, but what about the second wire coming off the injector harness, does that go back to a common ground?
bayer-z28
07-29-2012, 09:02 AM
See if this helps.
http://cs.chevroletclub.net/graphics/manuals/56/system.wiring.diagrams.pdf
LS1MCSS
07-29-2012, 03:55 PM
Here ya go.
LS1MCSS
07-29-2012, 03:56 PM
It goes to a 15A switched power fuse.
stevieturbo
08-19-2012, 05:16 AM
Injectors on all cars receive an ignition based 12v supply. The each injector has a ground trigger to open/close the injector as required.
It is this wire you need for the controller.
The Alchemist
08-19-2012, 05:40 AM
Thanks for the replies guys. I got it figured out. Hopefully I'll have the system live in the next few days once things around here calm down.
