82cetuner
07-27-2012, 03:41 PM
ok so I got my M/T ET streets and front runners mounted and have been driving them around town, I am actually very impressed with the drivability of these things I would keep them on if it wouldnt wear them out fast.
I am starting wtih 25psi in the back keeping 35 in the front may move to 40. My car is very capable of a 11.1 11.2 pass I plan to take it easy on the launching the first couple times to see how the car reacts. I run a long torque arm and a lighter than stock flywheel so lifting the car off the ground is not a huge concern I doubt that will happen.
The tires seem to want to push the car strait I have let go of the steering wheel and I can feel that the back tires drive the car and keep it perfectly strait so I know the rears are good and matched.
I was thinking of a 3k to 4k launch which is getting close to my max torque band and I am shifting at 6600 rpms 200rpm past my max hp.
What I am needing advice on is burnout procedure, wet them or no?
also would love some advice from someone runnign the same tires with close to the same HP.
i am a full weight car also.
