Wire hide pictures are gone! Helppppppp
OK.
i know the basics but i need help on one thing real quick and if i need more help, i will ask later
but right now i have relocated my traction control
and i need to know what i need to do when disconnecting this thing
can i simply unplug it or will i need to clamp it... i dont even know what it is...
but thanks for looking and thanks in advance
its the vacuum hose for your heater a/c controls. no clamp needed. just pull it off and route it with the rest of the wires then hook it back up
btw, let me know if your cruise still works afterwards. assuming you dont extend the traction control wires anyways
My ASR box under the hood is unplugged and my cruise control works. If you notice, there are two cables going into the box, and only one coming out going to the throttle body, where as the cars without traction control have two going to the throttle body. One for the throttle, one for the cruise. Cruise control, ASR or not, is controlled and completely separate from the ASR.
Where did you guys cut your hole! How big of a diameter do I need? 1.5"?
And what did you use as a grommet for that cut?
Also did any of you relocate your 4 ground wires (2 near battery, 2 near fuse box)
