any good easy way of removing tint?
if you're gonna get it retinted. I'd just let the shop do it. I just had mine retinted, and the shop pulled the old stuff off for free. They used a steamer to heat it as they pulled it back, and then used cleaners/razor blade to get the remaining residue off.
is the 5% on the sides or hatch? or both?
I've had to take of my 5% tint right around 20 times because of tickets here in CA. It's really easier than you think, the razor won't harm your window as long as your not cutting into your window and simply tilting the blade and sliding it along the glass. A new razor blade and a small bottle of soapy water and you can have the tint off and window clean in under 5 mins each side. The hatch is a little harder because of the defrost wires but side windows should be a piece of cake.
If you can manage to scratch the glass with a razor blade, congratulations you have managed a feat.
http://allprowindow.com/index_files/Page1419.htm
Professional shops use basically a steamer you can pick one up (rent one) that removes wallpaper at home depot and use it on your car, doesn't damage the car then. I agree with others on here let the shop do it and save yourself the time. But just wanted to give you another option.
I absolutely 100% want to have a shop do it, problem is they are 1 hour away and will only do it if I get new tint and i don't want tint anymore. It's more hassle than it's worth
When I bought my car it had really light tint on it. 35% I think. The tint pulled off very easily and for the glue I just used a hair blow dryer and mine came off easy with that too. But if the tint shop will pull it off for free just let them do it. Less hassle and more time for something else.
The soap/bag technique works well on the hatch window with defrost.
