Carbureted LSX forum - Air cleaner
View Full Version : Air cleaner
josh2002-ws6
07-28-2012, 05:08 AM
I just switched to a carb style intake with a top mount 4 barrel throttle body in my 02 WS6. I have already cut away the plastic and metal under the windshield. The throttle body has a 4150 size opening. I was wondering what air cleaner guys with 4th gen F-bodies are running? Thank you.
team39763
07-28-2012, 02:08 PM
I went with a Holley Fre Flo(I think). Its that little triangle one and i think Edelbrock makes one too. It fit fine until we needed to bolt on the nitrous plate and 2" spacer.
snook
07-29-2012, 06:36 PM
I wouldnt use the triangle shaped foam filters. They are rock catchers at best, lol That foam deteriorates fast and gets sucked in the carb too easy.
team39763
07-30-2012, 09:26 AM
Good point. I've heard the same about the foam. The owner of the car wasn't going to run a filter, but I convinced him to use the one of these for storage and on the way to the track(he only lives a mile from his track).
josh2002-ws6
07-30-2012, 11:37 AM
That's what I was looking at running. I am not worried about having to put a plate in or spacer as my car is running 2 stages of direct port. I just wasn't sure if the filter would fit under the hood.
I think I will only be running the air cleaner on the car when on the street, I plan on running the throttle body open at the track. Is that ok to do?
kmspruill242
08-02-2012, 09:11 PM
I have the same cleaner.... It's not very good. I have a dyno graph with two runs. One with the cleaner, one without. It's a 25 horse power difference. I ended up taking the foam out and using a head sock that looks like panty hose as a filtering element. The same things black guys wear.
josh2002-ws6
08-02-2012, 11:31 PM
Can I get a picture of the air cleaner with the head sock?
1badeagle
08-03-2012, 12:09 AM
This made me laugh really hard. Maybe because its after 1 am. I dont kow.
old93camaro
08-03-2012, 11:02 AM
its called a wave cap here is a link
http://www.walgreens.com/store/c/wavebuilder-wave-cap-2-pack/ID=prod355539-product
