Pushrod length
Pushrod length
Some one please double check my math for me. I'm installing stock unmilled 243 heads with double .660" springs, a MS3 cam and LS7 lifters on a stock LS1 stock block. I have the pushrod length checker from COMP. I've read LS7 lifter preload should be between .050-0.080 so I figured .070 preload should be good I turned the checker 10 time .050x10=.500
6.800" +0.500"= 7.300"
7.300+.070=7.370"
So the 7.375" pushrods I got should work just fine, Correct? Or am I off some place?
7.300+.070=7.370"
