Big Bu Bu
07-28-2012, 04:23 PM
Have track day wheels but no TPMs? Unless you go with TPMs on the track wheel set, no worries about disabling traction control. In the fuse box behind the driver side and under the rear seat, move the third fuse from the left (trunk release) to the fifth (spare) slot. This disables the key fob so be careful not to lock yourself out. The TPM display on the dash will show dashes instead of pressure values. The car will now go into Comp Mode or complete disable mode without receiving a signal from the TPMs. Thanks to Junior1 for the heads up. See blurry picture below
http://i1073.photobucket.com/albums/w382/mikesummers/Picture078.jpg
