what big cams fit with PP LS6 heads 59cc
Old 04-03-2004, 11:29 PM
BAD2000Z28's Avatar
Default what big cams fit with PP LS6 heads 59cc
what big cams fit with PP LS6 heads 59cc? Because they arent milled, what kind of big cams will fit without flycuting? G5X2 (232/240), G5X3 (?????), TSP Magic Stick v.1 (238/242), Magic Stick v.2 (239/244), TR "Trex" (242/248). what "big" cams are people using with these heads?
Old 04-03-2004, 11:59 PM
Beast96Z's Avatar
I know the X2 and the X3 on a 114 will fit. I do believe the Magik sticks were being designed to fit also. The t-rex won't because it maxes out the clearence on stock heads, so any valves bigger than stock will cause clearence problems. If you go with a 2.05 valve over the 2.02, your choices get even smaller.
Old 04-04-2004, 11:25 AM
EVIL's Avatar
what if you have valve reliefs in the pistons on the trex?
my trex is on a 114 lsa.
Old 04-04-2004, 12:26 PM
Beast96Z's Avatar
If you have valve reliefs, then you should be fine. I was assuming stock short block with no cuts.
Old 04-04-2004, 01:10 PM
jtz28's Avatar
Go with the AMS 239/236 Cam, its what I run. I put down 420/436 through my 3.42's (A4)
I gained a crapload of power over the old TR224 cam I used to run.
Old 04-04-2004, 01:13 PM
EVIL's Avatar
those numbers are locked right?
Old 04-04-2004, 01:20 PM
jtz28's Avatar
400/436 UNLOCKED
Old 04-04-2004, 01:23 PM
EVIL's Avatar
those are pretty good numbers.
what times have you got?
Old 04-04-2004, 01:27 PM
jtz28's Avatar
7.18@97mph with my current MW 4200 2.7str Converter. (1.68 60")
I hope to break 6's when I put in a yank.
Old 04-04-2004, 01:33 PM
EVIL's Avatar
nice!
Old 04-04-2004, 02:23 PM
pdd
pdd's Avatar
im goin with the FM11
