Gen 5 Camaro External Bolt-On Tech - Launch Control
Midnight00SS
07-29-2012, 09:03 AM
Tried it out yesterday and had it in competiton mode, clutch pedal to the floor, on gas all the way in the first gear, but i didnt notice the rev limiter coming on?? i thought it would? anyways so i let her go at about 4k and left alot of rubber, but felt the car trying to hook up and reduce the wheel spin
lazerlemonta
07-29-2012, 09:19 AM
Just hold it to the the floor and it will back the RPMs down itself. It's not a two step. The computer will close the throttle itself
Midnight00SS
07-30-2012, 08:58 AM
gotcha i will try it again
Dan2510
08-05-2012, 06:11 PM
careful with launch control...wouldnt wanna snap an axle or anything like that. Tried it once, horrible wheel hop. Now I'm finally getting use to slipping the clutch for better launches.
Midnight00SS
08-06-2012, 10:57 AM
i didnt get any wheel hop at all, doesnt that hurt the clutch??
ramairetransam
08-06-2012, 11:12 AM
does launch control work on 2010 maros , a friends has one and he hasnt been able to get it to work .
Dan2510
08-06-2012, 06:29 PM
It does wear the clutch more, but its just as bad with all the shock you put on the drivetrain using Launch Control. I launch around 2800-3000 and slip the clutch with limited wheel hop.
lazerlemonta
08-07-2012, 06:55 AM
I've got over 60 passes and never once had wheel hop. I leave at 3-3200 with a quick slip also.
Midnight00SS
08-07-2012, 08:43 AM
\are u guys running drag radials or the stock tires?
Aries
08-07-2012, 08:42 PM
Launch control does work on these cars. But if you ease into the gas it will stay off. You basically stab the pedal to the floor and it will spike to 4k and stop.
The down side to this is that stock axles and ring gears are very weak and a lot of people break them using launch control even on stock tires.
Midnight00SS
08-08-2012, 08:55 AM
can u upgrade the stock axels and how much is it??
Aries
08-08-2012, 09:43 PM
Driveshaft Shop (http://www.driveshaftshop.com/featured-products/chevrolet-2010-2012-camaro-v8-1000hp-level-4-direct-bolt-in-axles-set)
These guys are sponsors, and the best in the business. As always with IRS cars though, you have to pay to play.
Gunslinger09
08-08-2012, 10:18 PM
Yeah $1200 is way more than I am willing to pay.
ChargedCamaro
08-09-2012, 04:49 PM
They are well worth the price
Midnight00SS
08-11-2012, 02:48 PM
easy to install?
Gunslinger09
08-12-2012, 08:48 AM
easy to install?
From what I understand they take about 90 minutes to install with hand tools.
Midnight00SS
08-12-2012, 09:22 AM
thats not too terrible
Aries
08-12-2012, 10:11 AM
Yeah, 90 minutes if you've never done Axles on the IRS cars before. If you have, it gets down to about 40 minutes. Normally you only need to do them once though, and then the ring gear is your new weak point.
ChargedCamaro
08-14-2012, 11:13 PM
easy to install?
Easy, takes an hour max!
Midnight00SS
08-16-2012, 09:14 PM
ok cool
