Drag Racing Tech - who flashes and stalles off the line
98camarosixo
07-29-2012, 10:59 AM
Just wondering if people have noticeable results. Doin one over the other. Also what size stall and how high are you'll launching at
98TADRIVER
07-29-2012, 12:13 PM
when i had my P.I. 3400, id usually stall it to 2500 and then floor it. 1.49 60' on 12-11-11
with my circle D 5C converter, i usually stall it to 3400-3500rpm and then floor it from there. seems to be the best technique for me.got a 1.46 60' from it on 6-15-12
98camarosixo
07-29-2012, 02:01 PM
That's baddass I stalled it about 1800 I cut 1.66.I just put new slotted n driled rotors n brakes all the way around.becuz I tried it at 2500 but car wouldn't. Hold
Mighty Whitey
07-29-2012, 02:57 PM
If the car 60's better by "smacking" the converter off idle, then it's too tight to begin with, seeing as a converter will flash higher than it will foot brake too.
With my 10" edge 3400, I pulled numerous 1.54 60's with a 15-1700rpm launch, pulled a 1.52 by stalling to 1800, and I can foot brake it to 28-2900 easily. Waiting for cool weather and possibly try some 2-2200rpm launches to see if it helps the 60' any more
98camarosixo
07-29-2012, 05:11 PM
I recently went to track and flashed. It I only pulled a 1.8 60 ft so next time I go bak ill stall it as high as I can and see what 60 ft ipull
thunderstruck507
07-30-2012, 11:17 AM
I have tried doing both several times and it seems to make no difference but the car is more likely to hook if I smack it from idle.
BlackScreaminMachine
07-30-2012, 11:40 AM
Not that any of my stalls were anywhere near what the average NA car runs but I always seemed to do better with slight throttle input (1k RPMS) and whacking the throttle.
98camarosixo
07-30-2012, 12:06 PM
So I guess its trial and error. Can't wait Togo back to track sucks that its 2hrs away
Zero4488
07-30-2012, 08:58 PM
Was hooking 1.60's leaving off idle with an FTI 4400 with my stock long block with bolt ons...depends on the combo and the track...
98camarosixo
07-30-2012, 10:34 PM
Nice I just set my pinion angle it was way off also my lca were off also hopefully that will. Help
01ssreda4
07-31-2012, 01:57 AM
Mine is about the same in the lower rpm range. But if I load up too high it will start to lift the ass of the car which makes it hard to squat once you release the brake....and less chance to hook like mentioned above.
EZZZE
07-31-2012, 04:27 PM
Yank PT4000...I footbrake it til it bout pushes through the lights works best for me. Slows down when I flash it off idle.
98camarosixo
07-31-2012, 08:11 PM
I just did my pinion angle and my lca angle. It must been way off.cuz something would always hit the undercarriage around the back seat when I go through bumpy roads.now with everything. Set no more hitting or bumping on undercarriage I saw where yoke n torque arm wer hiting the floor.hopefully this will help wit my 60ft
its turbo time
08-20-2012, 04:04 PM
How far off was your pinion angle? I get that noise with a passenger over big bumps, my cars lowered though.
TXCatfish
08-21-2012, 09:11 AM
4k stall, I leave around 2300-2400. Cuts 1.61 in summer heat. 2500 is little hard to hold at the light.
Heyfred
08-21-2012, 10:19 AM
4K convertor, leave 2,300, 1.53 60ft.
Coach 02 A3 Z/28
08-21-2012, 04:59 PM
6200 convert, leave 3,800 rpm, 1.38-1.40 60ft in the Texas Summer heat!:nod:
Coach
B18B1LS1
08-21-2012, 08:13 PM
My PT4400 was the same, the higher I could stall it at the lights the better.
chrs1313
08-28-2012, 09:14 PM
Flashing slows down 60ft by around .05-7...but could help hook on marginal track
If you got teeth on your track stall her as high as the brakes will hold...
1.281 60ft here with h/c na motor at 3k race weight...
Still would like to try and running dual rear calipers to see if I can squeeze a few more .01s :)...maybe if I get bored
Dirty Vegas
08-28-2012, 11:51 PM
Holding 3300-3400 with my SS4000 usually gets me around 1.50-1.52 on a good track, 1.54-1.56 on a less than great track.
01ssreda4
09-02-2012, 11:36 PM
Every converter/car/combo is different. One size fits all does not apply here.
its turbo time
09-12-2012, 04:33 PM
My circle d 3200 liked to be flashed, prolly cuz it was so small
My 3800 edge hooked once by flashing and i did a 1.66. I might try stalling ut up next time
My PT 4800 liked to be stalled as high as possible without pushing through the brakes.
Kent1
09-14-2012, 01:01 AM
Yank SS 4000 Stalled between 2000 to 2700. Sixty foot ranges from 1.51 to 1.55! Pinion angle was set at 1 degree in past and reset it to 2 degress today!
