Head bolts or head studs??
Im doing a somewhat budget build on a motor. It will be a 370 with a D1 with a 3.4 pully so it will be seeing some boost. Maybe 16-17# I would think? Anyways, im debating on head studs or head bolts. Im trying to save money where I can but I dont want to save $150 somewhere to regret it later if you know what I mean. That being said, will arp head bolts work or do I need to stud it and why? I like the idea of haveing bolts for the rare instance of being able to take the heads off with motor in the car if need be. Other than that, its just about the money.Im not sure what the combo will make but I would assume 750 wouldnt be out of the question. Heads will be 317's.
Studs.
(boost depends on cam and several other factors as well such as RPM, elevation)
More so, is the crank pulley size... if your using a 7" or 7.4", 17 is not going to happen. Probably require 8+ inch custom
