brutalis
07-29-2012, 02:13 PM
I've done some searching, and can't seem to find an answer. I finally got my 98 T/A running yesterday, after installing H/C/I/E, new Innovate big 3, 99+ converted harness, and a new PCM with a Frost tune. All seemed well, until I took it out for a drive. After about a mile, it just shut off, and is now completely without electrical power. I checked the battery connections, all the grounds, all the fuses and relays, and can't find anything wrong. I've heard this could be an ignition switch issue, but I haven't been able to check because the car is currently stuck in a parking lot. Any other suggestions? I have to drive 200 miles back to work this evening and won't be able to work on it again until next weekend, so if I could get it back up before then, it would be a huge help.
