Dynamometer Results & Comparisons - My dyno results, cam only LS2...
View Full Version : My dyno results, cam only LS2...
Iron Indian
07-29-2012, 05:47 PM
I did this awhile ago. I don't post on here much but I figured i'd share this for the hell of it. The car is an 2005 GTO A4 with 81,000+ miles on it. I have about 2,000 miles on the "build". Its a cam only build, stock 243 heads, Stock LS2 MLS head gaskets, stock LS2 intake, stock LS2 TB, stock trans with a stall. Here is my detailed mod list...
Engine/Performance Modications:
-Varram Cold Air Intake
-MSD 8.5mm Plug Wires
-NGK TR55s @ .050
-Ed Curtis LSX "StreetSweeper-XL" Camshaft (Actual Specs, Lift: 631"/612" Duration: 236*/240* LSA: 111)
-Comp Cams Rocker Arm Trunion Upgrade
-PAC Racing 1221 Severe Duty Dual Valve Springs Max Lift .650”
-FTI Hardened & Machined Spring Locators
-FTI Seven Degree Titanium Retainers
-FTI Hardened Seven Degree Valve Locks
-Steel Shelled Viton Valve Stem Seals
-ARP 134-3610 Pro-Series Cylinder Head Bolt kit
-FTI Pro-Series 7.400" Hardened Pushrods
-Morel/Lunati Link Bar Roller Lifters
-LS2 3-bolt 24X Billet Single Row, Roller Timing Set
-Melling Standard Volume, High Pressure Oil Pump
-ARP Crankshaft/Harmonic Balancer Bolt
-OBX Long Tube Headers 1-7/8" Primaries/3" collectors 304SS
-OBX 3" Mandrel Bent Catless Mid-pipes 304SS
-OBX 2.5" Mandrel Bent Cat-back w/ Straight through mufflers and tips 304SS
-Tuned by Abel Racing in Midwest City, OK
Transmission/Performance Modifications:
-FTI 9.5" Torque Converter SRLS0086 (3700-3800 Stall)
-B&M Super Cooler Polished Transmission cooler (PN:70265) w/ Steel Braided & AN-6 cooler lines
The results, it dynoed 406.16 RWHP and 370.52 RWTQ on a Dynojet at Abel Racing. Dyno sheet is posted below. Donno how well she did compared to others but I can't complain.
The the future i'd like to go to an SD tune to get rid of a few cold start quirks prob a 2 bar setup so i can run lower fan temps since she runs 185-190 degrees. Not sure if I should play around with gaps or not on the plugs. Prob add a catch can. Eventually i'd like to do a Fast setup and maybe some heads.
mercccc
07-29-2012, 06:48 PM
Are these unlocked dyno numbers? Pretty good for a stalled auto. Hows it drive. I got one of Eds cam going in my new motor.
Mazzenger
07-29-2012, 07:02 PM
Seems strong.
Slowhawk
07-29-2012, 07:28 PM
Looks good. Built a few 05/06 stalled gto's like yours. The unlocked runs murder the dyno numbers.
Iron Indian
07-29-2012, 08:59 PM
Feel like an idiot but are you talking about the converter being locked or unlocked? I know when he dyno tuned it he didn't do any tricks to the trans to keep it in a certain gear or anything. He just started it up and gave her hell. Think he dd the WOT part in third gear. I have a couple dyno videos on my iphone. Now to figure out how to get them on here.
Iron Indian
07-29-2012, 09:19 PM
As for as how it runs and drives, it drives great! Can't even tell it has a stall honestly. It could easily be driven daily other than th rough idle which doesn't bother me a bit. :-)
Only quirk is starting it up especially cold I have to hold the revs to about a grand for about 30 seconds before she'll idle on her own. I believe alot of that is the MAF and the Varram. From what i've heard on other GTOs going with an SD tune cures alot of that. Plus if I go to a 2 bar map i can adjust my fans sooner than 194 degrees.
