Mazin
07-06-2012, 02:30 PM
Guys, this is my brand new Snap on welder. I've recently lost my job and need to get rid of some things asap. :(
TRADES: fox body mustangs, ls1 cars or parts. T-56 transmission and swap parts. Just let me know what you have. I'd rather have cash but I'm open to offers.
For sale: Snap-On part# MIG220. Welder has NEVER been used. Never even been plugged in yet! Brand new.
Description: Specifications: Input
- Voltage: 208/230 VAC - Amperage: 40 - Single Phase Frequency: 50/60Hz Output - OCV Range: 15-37.5 -Arc Voltage: 10-28 - Amperage @ 100% Duty Cycle: 140 AMP - Amperage @ 60% Duty Cycle: 180 AMP - MIG Settings: 12 - TIG Settings: 4 - MIG Current Range: 30-250 AMP - TIG Current Range: 80-250 AMP MIG Torch Capacity - Amperage: 250A max - Length: 10 ft. - Wire Size: .023-.045 (3/64 inch) - Max Speed: 800 in/min
MIG220 includes: - MIG220 power source and wire feeder - Industrial wheel kit and cylinder rack -Flow-meter â€"regulator - 20 ft. power input cable - 10 ft. ground cable - 250A MIG torch with 10 ft. cable Features:
12 MIG settings - 4 TIG settings All copper windings for extended duty cycle and performance Silicon steel laminations are bolted and insulated for high efficiency Voltage taps for exact control for output Triple insulated transformer windings All metal drive gears â€" cast aluminum wire drive system Cooling fan for extended weld times Quick changeover to gasless and TIG welding Voltmeter indicates OCV or arc voltage Aluminum spool gun ready and a DC TIG attachment can be added as an optional accessory* Comes complete with gas regulator-flow-meter DC stabilizer choke provides smooth arc Cabinet made of all metal 16 gauge case for durability, 12 gauge base - Controls on the front of unit are easily accessed
http://i246.photobucket.com/albums/gg106/Schylor/IPhone3GSDownloads020.jpg
May also text: THREE ONE SEVEN - NINE EIGHT NINE - EIGHT ZERO SIX TWO
Thanks for looking!
Price is obo.
Thanks for looking!
Price is obo.
