Gears & Axles - Strange S60 and brake brackets???
View Full Version : Strange S60 and brake brackets???
RealLiveMD
07-29-2012, 09:08 PM
This install is giving me a few problems. The brake line bracket is too small and won't fit over the back of the LCA bracket as ait does in stock form. Any suggestions other than tack welding. I included a pic where I have a bolt in one side and then using the BFH mod to try to bend it but it's not going to happen. What did you guys do???
RealLiveMD
07-29-2012, 09:12 PM
hopefully, here's the pic
RealLiveMD
07-29-2012, 09:24 PM
after searching, I think this is a common problem. I guess I'll dremmeal off the other side of the bracket.
b0b
07-29-2012, 09:48 PM
Look at my thread I just posted of my S60 install. You may be able to dremel enough to get it to slide on, it is gonna sacrifice strength though. That is if you can even take enough off to get it to slide over. There is a pic in my thread of where I cut it and bolted the two halves on with the LCA and everything, once in place you can weld the two pieces of bracket back together. It takes some hammering and bending, but I think it will be stronger than dremeling the inside of the brackets thin enough to slid over the LCA bracket. Good luck with it!
t5munoz
07-29-2012, 09:50 PM
I cut one side of the bracket off and bolted it to the relocation bracket
oldmano2z
08-01-2012, 02:59 PM
i did the same cut one side off and drilled a hole on the back side of relocation bracket by the stamped tab put a 5/16 bolt and nylock nut and called it good not a stressed point only used when brake is on. the oldman...
