General Maintenance & Repairs - disconnected vacuum tube
View Full Version : disconnected vacuum tube
Kyle Kinnamon
07-30-2012, 10:20 PM
OWhat does this tube go to. I can't seem to figure it out.
2000 ls1 camaro
http://i133.photobucket.com/albums/q48/igothoes7/IMAG0710.jpg
usnfenix
07-30-2012, 10:24 PM
that is one of the provisions for the AIR system, and it goes to a black cylinder looking thing that has several other tubes comming off it. i had and idle problem that had somewhat to do with a vacuum line being disconnected.
Sales3@Texas-Speed
07-30-2012, 11:08 PM
Agreed, part of the AIR system, if you currently have or are planning on getting headers this can be deleted and removed.
1BadBlkB1tch
07-31-2012, 01:30 AM
yes delete this totally worthless when you have LT's Tsp 1 7/8's run the best for there price and i put down 27rwhp with em :-P (mustang dyno at that)
Kyle Kinnamon
07-31-2012, 07:59 PM
I have Texas long tube headers with egr, cat and air pump delete. What can I do with it if its not being used? I noticed it starts to have a vacuum on it after a few mins of running.
00ZNewb
08-01-2012, 05:40 AM
Pull the rubber 90 degree fitting off and cap it. Anyone know if this hose or the place it connnected has anything to do with the cruise control system. I deleted my AIR and i lost my cruise.
Sales3@Texas-Speed
08-01-2012, 09:25 AM
It shouldnt, if you disconnected the air system under the fusebox on the drivers side, I would check to make sure that you didnt unplug cruise control as well.
777
08-01-2012, 09:52 AM
Push the 90* angle on top of one of the bolts that hold the coil packs on. It's a perfect fit. No more vacuum leak.
