350 engine COMPLETE vortec headed
Category: Engine - Complete Motors
Price: $1800
Part Fits: 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): LA
Item Condition: Used
Engine: Small Block
LS Engine?: Non-LS Part
350 bored .060 9.8:1 cr
Ported/polished vortecs, 2.02/1.6 valves, milled 61cc, 3 angle VJ, bowl blend, etc...was said to run with a set of AFR heads when i got that work done
.028 head gasket
180 t-stat
weiand airstrike intake w/1" 4 hole spacer
750 edelbrock electric choke carb-----will also included the FULL rod and jet kit for this carb as I've never had it tuned/jetted...so more power there
Accel dizzy w/wires plugs gapped at .045 ACdelco
1.5 stock stamp rockers
Lunati voodoo 60103 w/comp 941 springs
K&N air filter
A/C compressor
New alternator
New Starter
New Flywheel
New waterpump-----also have an extra new pump that I would throw in also
New power steering pump
New Holley fuel pressure Regulator
New Edelbrock Mechanical Fuel Pump
Flowtech LT Headers
10 extra quarts of Valvoline VR1 Racing Oil----MUST be used with this engine as it has good ZDDP for flat tappet cams
Serpentine setup
Also have a dual snorker air cleaner you can put on to that I will throw in there too.
its a drop in and go engine and I put this engine on I-20 faithfully on the weekends..will only remove from my car when i have payment CASH ONLY!!! NO LOW BALLERS SERIOUS INQUIRES ONLY
PICK UP ONLY or I can deliver up to 150 miles BUT you have to pay for my GAS there and back which should only be a tank. I WILL ONLY REMOVE FROM MY CAR WHEN I HAVE CASH IN HAND so it's best you come look at it, we can drive it around or whatever you like. I DONT HAVE TIME FOR SCAMS so dont waste my time and yours...
Thanks
Last edited by 87caprice318; 07-31-2012 at 10:27 AM. Reason: put in correct category
