Notices
Needed: Titanium Retainers for Trickflow Valve Springs
Old 07-31-2012, 10:57 AM
Rtzracer's Avatar
Default Needed: Titanium Retainers for Trickflow Valve Springs
Here are the specs:
Number of Springs Per Valve Dual
Outside Diameter of Outer Spring (in) 1.295 in.
Coil Bind Height (in) 1.100 in.
Damper Spring Included No
Spring Rate (lbs/in) 448 lbs./in.
Inside Diameter of Inner Spring (in) 0.686 in.
Valve Spring Style Standard
If it matters. I need a set of retainers preferrably titanium.
Thanks
Old 07-31-2012, 11:25 AM
Brian Tooley Racing's Avatar
Originally Posted by Rtzracer
Here are the specs:
Thanks
Got em! $129 shipped. http://www.briantooleyracing.com/tit...e-springs.html
