Drag Racing Tech - Wiring Hick Up!!!! HELP!!!
View Full Version : Wiring Hick Up!!!! HELP!!!
Zero4488
07-31-2012, 04:24 PM
I was certain a few months ago I saw a thread about having your power windows and locks work with out the BCM....I've searched and searched and can't find it....So here is my question I've been trying to get my power windows and locks to work both with and with out my bcm....with the bcm hooked up I only have door locks and it doesn't unlock...If I hook up power to the 12v to the brown wire for the window control module only the passenger window works....for lack of a better question what do I do to make the factory door harness work?
-Dave
Zero4488
07-31-2012, 05:09 PM
I ironed out my window issue...have everything working including the auto down....now what about the rest of the bcm...is their a way to apply power and have the dome light and power locks work? Don't care about the key fob....
Zero4488
07-31-2012, 05:39 PM
Is their a way to hook up the BCM without the PCM and have the creature comforts work?
Freeman83
07-31-2012, 06:05 PM
You can use a couple relays to manually wire the doorlocks. Then just use a two way switch or keyless entry to trigger them.
Freeman83
07-31-2012, 06:11 PM
You could also use the factory lock switch to trigger the relays....forgot to mention that lol
ccd_1606
08-04-2012, 09:11 AM
Just wire a set of relays and the door locks will work, and i just deleted my bcm a few weeks ago. All i did to keep the power windows working was give power to the 14 gauge blue wire off the bcm. Auto down works and both switches work.
Zero4488
08-04-2012, 07:15 PM
So does anyone one have a diagram to wire door locks?
