BIGDATOWN
08-01-2012, 08:33 AM
2001 Camaro Z28 A4 with 172k miles. Car has nice black leather interior, cold a/c. Everything works on the car. The car has two issues. 1. It has a slightly burnt exhaust seat on cyl#6 resulting in slightly lower compression on that cylinder than the rest and causing a CEL. This cylinder still produces 180 PSI but all others are around 220 PSI. 2. I believe the car has a weak lifter in it as it does have a slight tick after some rpms. Other than that the car is solid. I Have put alot of time in this car to make it as close to perfect as possible AND I still daily this car everyday. No cheap parts were bought.
Aftermarket parts are:
PTC 3500 10" converter
Transgo HD-2 shift kit
Derale trans pan with built in cooler
16,000LB External trans cooler
Autometer trans temp gauge
Innovate wideband MTX series
Slp Lid/kn filter
Bo White TB
BBk Longtube/ORY
Custom 3" exhaust through a 18" magnaflow
New parts are:
New fuel pump assembly
Motor/trans mount
Water pump
Belts/plugs
Oil pan gasket
Rear cover gasket/ rear main seal
Valve cover gaskets
Main vacuum T/ Bought from GM
Corvette o2 sensors
Car has ran a best of a 7.87 with me in it (330lbs) and a 7.75 with slota in it (175lbs) on a set of 235 et streets, and a best of 8.14 (twice) on khumo street tires. This car has alot of potential left in it. It has not even been tuned yet! Here is a video of its first time out with the new parts before the custom exhaust. Video is with the stock cat-back and a 3" cutout.
http://www.youtube.com/watch?v=KGn_IwV_2Aw
I'm asking 6K O.B.O. All of these parts are only a few months old. 256-572-711zero Text or call if interested in buying or trading.
Slp Lid/kn filter
Bo White TB
BBk Longtube/ORY
New parts are:
Motor/trans mount
Water pump
Belts/plugs
Oil pan gasket
Valve cover gaskets
Corvette o2 sensors
