Generation IV Internal Engine - Need a little help with my build
Formula WS6
08-01-2012, 12:43 PM
I'm swapping my LT to LS. I have an 04 LQ9 short block, lingenfelter ported ls3 heads/ intake and fuel rail/ injectors. I've ordered a custom cam from EPS and in effort to achieve the most power out of my combo, I need some suggestions on which head gasket to use. Preferably thinner than stock to bump up the compression a bit. I am aware and planned on fly cutting the pistons to be on the safe side. Any help would be appreciated.
Paul
JUSTINSWS6
08-01-2012, 12:56 PM
Alot of places sell the thinner gaskets think there is a.041 size. You coul also mill the heads to get a higher comp ratio. What tyoe of comoression are you wanting?
JUSTINSWS6
What piston are you going to run?
JustinCody
08-01-2012, 02:25 PM
I got .040 cometic gaskets from TSP.
Sales4@Texas-Speed
08-01-2012, 05:24 PM
We sell a lot of the Cometic .040" gaskets. If you are willing to flycut that would be the way to go in my opinion.
Formula WS6
08-02-2012, 08:25 AM
Thanks for the replys. I plan on using the stock LQ9 short block. I'd like to achieve close to 11.5:1 . Sounds like the .040 is the way to go, thanks
Formula WS6
08-15-2012, 12:17 PM
Just received the head gaskets from texas speed and now I'm on to which timing chain to use. C5R or is there something else out there that's the better?
litle88
08-15-2012, 06:03 PM
There is no better bud, does the block have the bolt holes to put an Ls2 chain dampner?
litle88
Also get an UDP either 10-25%
JUSTINSWS6
08-15-2012, 06:25 PM
Get a ati pulley they are the best by far
Formula WS6
08-16-2012, 07:34 AM
Thanks Zeke and Justin. I'll check the block tonight to see if it can accept a t/c damper. forgot to bring home my balancer puller last night
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
