jrob56
08-01-2012, 03:18 PM
Here is everything that I took out below, not sure if its all police or an alarm system or what. But it went to the BCM it looks like, connected to wires in the driver door, a lot under the kick panel, and to a siren near the nose. Had a switch and an led too.
It was all removed without issue, and everything on the car works. Just a few loose ends if you will haha. A few of these connectors that I found are just loose and had nothing to do with what I pulled out, but still curious.
http://i230.photobucket.com/albums/ee60/jroberson88/IMG_3162.jpg
First this car only has fogs(left connector) no TCS/ASR, but there is another connector there(right), and two loose wires(middle). Any ideas?
http://i230.photobucket.com/albums/ee60/jroberson88/IMG_3160.jpg
Found this guy tucked up under the dash, no idea what it is or where it goes?
http://i230.photobucket.com/albums/ee60/jroberson88/IMG_3155.jpg
Here is one more I found tucked under the kick panel, one little wire cut clean? Ignore that big brown one that found its way into the pic.
http://i230.photobucket.com/albums/ee60/jroberson88/IMG_3156.jpg
Lastly is this lil AM/FM BC box stock? Think so but cant remeber from my old Z
http://i230.photobucket.com/albums/ee60/jroberson88/IMG_3161.jpg
