Generation IV Internal Engine - '09 6.0 Aluminum motor with L92 heads - Wanting to go Carbed
1QuickT-A
08-01-2012, 05:24 PM
This motor came out of a 2009 truck....what the hell is it? L76, LY6, etc??? I'm an old school LS guy so I can't keep all the L this, L that shit straight lol. Does this motor have VVT or DOD? I don't know how to tell the difference. I bought it as a long block.
I'm putting this motor in a mustang coupe with a Carb conversion. I am putting LS7 lifters in it, a custom L92 designed cam, pushrods & dual springs. What else needs to be changed on this thing in order to use the MSD 6010 style box? Do I have to put a LS2 style timing cover on it? I'm a little lost on this newer stuff.
Thanks,
Matt
-TheBandit-
08-01-2012, 06:31 PM
If it's an '09 aluminum truck 6.0, it is the L76 from the "VortecMAX" truck and would have both VVT and DOD/AFM.
1QuickT-A
08-01-2012, 07:23 PM
How do you tell if it has both VVT and DOD? 4 of the lifters had those goofy springs made onto them. What else do I need to look for?
I won't be using any of that garbage. I think I read somewhere that if you aren't using any of that you can swap out the front timing cover and use an LS2 cover???
TVWilkes
08-01-2012, 07:48 PM
The lifters tell me that it is DOD. What type of timing chain setup?
1QuickT-A
08-01-2012, 08:23 PM
I haven't pulled the front cover off of it yet.
-TheBandit-
08-02-2012, 07:47 PM
http://image.hotrod.com/f/techarticles/engine/hrdp_1007_gms_variable_valve_timing_system_perform ance_test/29378617+w200/hrdp_1007_09_o+comparison+of_a_vvt_timing_cover.jp g
VVT cover left, nonVVT cover right. Difference should be obvious looking at the area behind the waterpump.
1QuickT-A
08-03-2012, 09:35 AM
Definitely a vvt motor. So that tells me I need to find an LS2 front cover. Thanks guys.
raybob
08-21-2012, 08:37 PM
I am doing similar swap, keep us updated on the parts that you will be using.
