Subframe connectors before alignment?
Old 08-01-2012, 05:43 PM
Moon1949's Avatar
Default Subframe connectors before alignment?
Just picked up a 2001 T/A vert. I want to get the front end aligned but should I wait until after the subframe connectors are installed? I plan on getting the UMI 2 point bolt ins. I would think the bolts would get tightened with the weight of the car resting on the tires. So it doesn't seem like it would need to be aligned after the connectors are installed.
Also, does anybody have any recommendations for good alignment, speed shops in the Cincinnati Oh area?
Moon
Old 08-01-2012, 06:09 PM
trans_am7935's Avatar
your SFC's need to be installed with the suspension pre-loaded (tires on the ground/drive on lift). and it shouldnt effect your alignment, but if you get them in before you do it, then i would call it piece of mind to install them first
Quick Reply: Subframe connectors before alignment?
