best way to spin a short block while building
I'm currently putting together a ls1 short block. I've got the crank in and bolted in. It spun freely but as I added the pistons I can't find away to spin the crank as easy. I found an old crank bolt and tossed it in and it'll spin a bit and then I feel the bolt just stretching. It seems to be stuck between two points but it moves back and forth between those points. So my question is, can I find an easier way to spin the crank so I can tighten the rod bolts or is something messed up? Should it spin pretty easy with the pistons in? Maybe one of my piston rings is jacked up?
Closed ex-Sponsor Account
Jason, you just answered your own question regarding the rings; better to question now than 10 hours of labor getting the motor dressed and into the car
without the rods in, you could spin the crank using the snout/timing gear with minimal effort?
I'm assuming you've done the 140degrees rotation and the oe tq procedure on the stock crank bolt a few times, getting the bolt to 'stretch' as you posted is nuckin futs if you don't have a flywheel bolted on with the KMoore locking tool
