bad01gt
08-01-2012, 10:58 PM
1992 Ford Mustang GT with 94,500 original miles on it. The car is in immaculate shape and is one of the cleanest fox body mustangs I have ever seen. It is red in color and black interior. The car even has ice cold AC! The only thing the car needs is to have the driver side window retinted and the clutch quadrant adjusted. Here are the following modifications:
Tremec 3550 5 speed with Spec Stg 3 Clutch
Trick Flow Twisted Wedge Aluminum Heads
Trick Flow Stage 1 Cam
Trick Flow Intake
Trick Flow Valve Covers
Trick Flow 6.7" Push Rods
Trick Flow 1.6 Roller Rockers
Pro M 77mm MAF
24# FMS Injectors
MSD 6 GTM with boost retard
BBK 70mm TB with EGR
FMS Steel Timing Gears
FMS Crankshaft Dampner
MSD Coil
FMS 255 LPH Fuel Pump
FMS Shorty Headers
Steeda Fuel Pressure Regulator
Powerdyne Supercharger (rebuilt in Jan) 6&9 PSI Pulleys
8:1 FMU
Powermaster 140 Amp Alternator
Lakewood Lower Control Arms
Aluminum 3 Core Radiator
Weld Draglites with Skinny's & 275/50/15 MT Et Street Radials
Welded Subframe Connectors
3.55 gears with new bearings and seals
Dynomax Stainless Exhaust with Bassani X Pipe
Price: $11,000 OBO
Please text me at 229 - nine four seven - 9078 with any questions
http://i192.photobucket.com/albums/z99/ccape_46/c8519630.jpg
http://i192.photobucket.com/albums/z99/ccape_46/1fa186ed.jpg
http://i192.photobucket.com/albums/z99/ccape_46/36968095.jpg
http://i192.photobucket.com/albums/z99/ccape_46/d77f3d6b.jpg
http://i192.photobucket.com/albums/z99/ccape_46/c792e891.jpg
Trick Flow Intake
Pro M 77mm MAF
24# FMS Injectors
MSD Coil
FMS Shorty Headers
8:1 FMU
Price: $11,000 OBO
