Fueling & Injection - walbro intank with inline pump
a4ls2goat
08-02-2012, 12:49 AM
ive searched but getting mixed answers on this.
how much WHP will a walbro intank and walbro inline support?
this will be with a adj.FPR and return.(at 65psi) and 80lb injectors for a turbo setup.
thx in advance
2nd Gen Fl 'bird
08-02-2012, 12:37 PM
There's a few guy's on here pushing 8-900 hp with dual in-lines so, I would think your idea would be comparable which is the way I'm doing mine. My idea is if the in-tank pump craps out I can "make" inline work to get me home. Maybe I'm paranoid.:rolleyes:
kdavis
08-02-2012, 04:09 PM
Im debating using an intake and external on our mustang swap, or just using 2 externals with 10an to the regulator.
a4ls2goat
08-02-2012, 05:21 PM
People say that even having an inline is as worthless as having a single walbro intank.
Idk how. On my EVO8 I was making around 600whp and had a walbro 255 intank with a inline pump on e85. Never did the pumps max out and it still had more fuel if it was needed.
Mr. Fuel Pump
08-02-2012, 05:44 PM
If you run more than one pump in a series/inline, you will only flow to the engine as much as the last pump is capable of. However, if you run the pumps in parallel you will achieve more flow than just one is capable of, but not fully cumulative. A Walbro '255lph' HP will typically support up to 500whp at approx 60psi and in some cases close to 600, but that is pushing it. A dual/parallel set up will support around 750whp+
a4ls2goat
08-02-2012, 06:46 PM
If you run 2 of the walbro intank pumps in parallel in the bucket can they both be on at all time?
My6speedZ
08-02-2012, 07:31 PM
Some people do it and say it works fine, most run it off a boost switch.
MIGHTYMOUSE
08-14-2012, 01:34 PM
ive seen 640 rw with an intank and an inline
the head pressure gets divided over the two pumps inline, so for example at 60psi it will flow more like its only pushing on 30psi. definitely not double like with parallel.
a4ls2goat
08-18-2012, 08:00 AM
ive seen 640 rw with an intake and an inline
Thx for your input.
MM, what do you think of both walbros in the tank being ON full time?
With a fuel return ofcourse.
MIGHTYMOUSE
08-18-2012, 08:37 AM
people do it. i wouldnt.
idle doesn't need 1000 horsepower of fuel, all you are doing is making heat and being inefficient.
my 1200 horse trans am drove around on one walbro 99% of the time. 1% of the time i floored it and the other two came on without fail. (tho i always checked that they would before relying on it) still never an issue regarding triggering or the relay.
HPbyGD
08-18-2012, 09:00 AM
What do you guys use for check valves when you run multiple pumps ?
Thanks Gary
MIGHTYMOUSE
08-18-2012, 11:05 AM
they are built in to the walbro pumps, probably on the aeromotive and deatchwerks version pumps as well but ask first.
