General Maintenance & Repairs - oil consumption
kernandl
08-02-2012, 07:39 AM
My 2002 has 170,000 miles and has started burning oil now when driven hard. I'm assuming this is oil leaking through the valve seats? would a new set of aftermarket heads fix my problem? i've got heads and cam on my "wish list" anyway and if the new heads will fix the problem I could use as an excuse to the "Missus" to make this purchase a priority..:)
NC98Z
08-02-2012, 07:42 AM
Are you sure it isn't sucking the oil down the intake?
With 170k on the clock, and the fact that these cars typically burn some oil anyhow, it could be coming from anywhere. That's a pretty expensive "test" to see if you fix the oil burning issue. Especially considering that that's probably not the reason for oil burning. I'd check the PCV system first, then do a leakdown & compression test.
kernandl
08-02-2012, 08:22 AM
ok thanks , I'll check the compression and do a leak down test, not to famailiar with the PVC system and all it's components though. The car runs fine but when I mash on it she smokes like a diesel...
ragtopz28
08-02-2012, 08:32 AM
With that said...time for a catch can. It's blowin throught the intake.
conan
08-02-2012, 09:01 AM
When I pulled my 5.3L out of my yukon this winter for a failing oil pump, I found the oil scraper ring pack was stuck tight in the ring lands. I was burning abot 1 quart / 3,000 miles. They weren't seized or any thing they just had no spring left in them, they also had 224,xxx miles on them too.
So the catch can and new valve seals would be a good thing to do, it might not solve all of your problems.
roninsonic
08-02-2012, 05:12 PM
if if it's smoking that bad, it might be time for a set of rings... regardless, I'd try an updated truck PCV valve first. It's a five minute, three dollar test that might fix the problem before you start spending a shit-ton of money for no reason.
If it smokes on acceleration then it isn't bad valve seals then. Best way to check for bad valves seals is to watch for smoke on decel, allowing the engine to slow the car. The vacuum from the engine will pull oil in.
kernandl
08-03-2012, 10:34 AM
smokes just under HARD acceleration.
jrob56
08-03-2012, 10:38 AM
What color, every fbody Ive ever seen blows out some blackish smoke right on the hit once the cats are out.
LS1121
08-03-2012, 10:41 AM
maybe the rings, do you have any back pressure coming thru the engine? Is it puffing out the oil fill spout? Why do people just jump on the PCV are they really that clueless?
kernandl
08-03-2012, 10:50 AM
bluish black smoke. haven't noticed any oil around filler tube or leaks for that matter. and I have no cats..
kernandl
08-03-2012, 10:52 AM
and I can smell a faint odor of fuel (like runnin real rich) also.. but like I stated earlier , it happens only when I mash on it..
LS1121
08-03-2012, 03:59 PM
Hmmmm.....blue usually indicates oil burning and black is too much fuel. Ya really need to do a compression test and if that checks out OK have someone check your Tune.
kernandl
08-06-2012, 07:45 AM
Compression check looked good , tune is more than likely a big factor that needs to be addressed. I'm only using a hand held programmer for a tune at the moment.
jrob56
08-06-2012, 07:50 AM
Still sounds normal to me, havent seen an fbody yet that doesnt do that. If you say yours doesnt, you prolly havent seen it from behind when someone gets on it. It was worse before I got a tune on my current and previous fbody, but still does it.
LS1121
08-06-2012, 10:52 AM
most cars will give a little puff when you stomp on it, even my Civic will "puff" but the OP's post says Burning Oil that is a completely different thing.
jrob56
08-06-2012, 11:34 AM
I know what it says. Its an ls1 with 170k miles. I dont know a single ls1 that doesnt burn oil, let alone a higher mileage one. Just top it off, the smoke you are seeing on the hit is normal. Now if you start seeing consistent smoke through a whole run, or normal driving Id start getting worried. I just think this is a non issue.
LS1121
08-06-2012, 11:42 AM
OK so what exactly do you mean by burning oil? Tell us what the issue is exactly. Is it a small puff or is it smoking all the time?
Bacon
08-06-2012, 11:47 AM
Oil disappearing can be caused by more things than you can shake a stick at. Like mentioned earlier, burning some oil isnt an issue. Ive had GM V8s with 110k that burn NO oil, but ive also had ones with 30k on them that burn a quart every 3k. It could be as simple as switching to a different oil or even a different weight oil.
If you SEE smoke and its blue, then you are most definitely burning oil. If you see it on hard accel, its not likely the valves or guides. Valve guides usually will show their face in the form of a puff of smoke when you leave a stop light or a cloud when you start the vehicle up. Otherwise the burn is so small that you smell it rather than see it.
Did you do just a compression test or did you do a leak down as well? You may just be a little worn and burning some more under high load.
When you change your oil is it thin and gassy smelling? Its usually more of a dirty injector problem, but worn rings will let more fuel by and into the oil pan. Thin oil can more easily be burned off under high load.
kernandl
08-06-2012, 11:57 AM
i only notice the smokin under very hard acceleration. I've had people follow me and under normal driving there is nothing noticeable.
Bacon
08-06-2012, 12:00 PM
How much oil are you down at an oil change?
kernandl
08-06-2012, 12:02 PM
It only smokes through WOT. I did a compression check but not a leakdown test. I've been using Mobile 1 synthetic 10-40W . Been using this brand of oil since I purchased it with around 5K on the odometer in 2003. I smell no fuel in the oil and the viscosity is maybe slightly thicker than when I put it in but not much if any.
jrob56
08-06-2012, 12:05 PM
yep this all sounds like you have a very normal healthy ls1. If you have to sell the misses on the heads, youll have to do it another way haha
kernandl
08-06-2012, 12:06 PM
I change oil approx. every 3-3500 miles and depending on how often I hit WOT during that time frame , i usually have to add about a quart to a quart and a half before the next oil change.
kernandl
08-06-2012, 12:08 PM
JROB - hopefully she won't bother asking on the heads issue, although she did bust me on "the rear-end alignment" .. Excuse I gave for the rear tires always needing replacement...:)
Bacon
08-06-2012, 12:12 PM
psh, 1qt? Just leave it alone or drive at night so you dont see the smoke. Here is GMs response to how much oil consumption is "normal"
Here's gm doc 2222953, word for word:
Document ID: 2222953
#01-06-01-011F: Information on Engine Oil Consumption Guidelines - (Jan 13, 2009)
Subject: Information on Engine Oil Consumption Guidelines
Models: 2009 and Prior GM Passenger Cars and Gasoline-Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)
2009 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
This bulletin is being revised to update the warranty information on vehicles and add model years. Please discard Corporate Bulletin Number 01-06-01-011E (Section 06 -- Engine/Propulsion System).
All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. As a result, varying rates of oil consumption are accepted as normal in all engines.
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
Important: This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or driven at legal speeds in an unloaded (for trucks) condition.
Important: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more.
Many factors can affect a customer's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption.
Gasket and External Leaks
Inspect the oil pan and engine covers for leakage due to over-tightened, damaged, or out of place gaskets. Inspect oil lines and fittings for signs of leakage.
Improper Reading of the Oil Level Indicator (Dipstick)
Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked.
Notice: Operating your vehicle with an oil level that is below the minimum level indicated on the engine oil dipstick can result in severe engine damage. Repairs resulting from operating an engine with insufficient oil are not covered under the terms of the New Vehicle Warranty.
Important: Refer to Owner Manual in SI for checking and adding engine oil.
Not Waiting Long Enough After Running Engine to Check Oil Level
Some engines require more time than others for the oil to drain back into the crankcase. To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked.
Important: This does not apply to 2006-2009 Corvette Z06 equipped with the 7.0L LS7 and the 2009 Corvette ZR-1 with the 6.2L LS9 engines (dry sump). Follow the instructions in the Owner Manual for checking the oil in this application.
Improper Oil Fill After an Oil Change
Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner Manual or Service Manual for information on recommended oil quantity, viscosity, and quality.
Aggressive Driving, High Speed or High RPM Driving
Aggressive driving and/or continuous driving at high speeds/high RPMs will increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected.
A higher rate of oil consumption is normal for vehicles equipped with manual transmissions that are driven aggressively. By "aggressive," we mean operation at high RPM (3,000 RPM to redline), with frequent use of engine braking (using the engine to slow the vehicle). Vehicles that are driven aggressively may consume engine oil at a rate of up to 0.946 L (1 quart) every 805 km (500 mi). This is normal for a vehicle that is driven aggressively. No repair is necessary. This characteristic does, however, require the owner to check the engine oil level at sufficiently frequent intervals, especially when driving aggressively, to assure the oil level remains within the recommended operating range. As the Owner’s Manual recommends, you should check the oil level every time you get fuel.
Towing or Heavy Usage
Towing a trailer will increase oil consumption and may cause oil consumption to fall below the normal accepted rate referenced in this bulletin for an unloaded vehicle in a personal use application. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption.
Crankcase Ventilation System
Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use.
Oil Dilution (Fuel and Water)
On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, unburned fuel and condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture and fuel, may give the customer the impression of excessive oil consumption.
Engine Temperature
If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order.
Engine Wear
Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption.
Measurement of Oil Consumption
Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).
•Verify that the engine has no external leaks. Repair as necessary.
•Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
•Park the vehicle on a level surface.
•Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that the oil has had time to drain back into the crankcase.
•Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual.
•Record the vehicle mileage, date, and exact oil level on the form included in this bulletin.
•Ask the customer to verify the oil level, each time the vehicle is fueled, following steps 1-6 and return the vehicle to the dealership if the oil level is found at or below the add mark, 0.946 liter (1 qt) low. If the oil level remains above the add mark, the customer should continue to operate the vehicle and verify the engine oil level until 3200 km (2000 mi) has accumulated before returning to the dealership for a final evaluation.
•If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 3200 km (2000 mi), follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 3200 km (2000 mi), explain to the customer that their engine meets the guidelines for oil consumption.
Bacon
08-06-2012, 12:13 PM
I understand your vehicle isnt listed, but its about the same across the board for V8s
kernandl
08-07-2012, 07:52 AM
It's closer to 2 quarts a month....
jrob56
08-07-2012, 08:03 AM
First these two statements are contradictory unless you drive a lot!
Second read this section, I have a feeling you skimmed. I check mine a lot, and keep a quart in the car.
kernandl
08-07-2012, 02:32 PM
statement should've been every 2 months. driving back and forth to work alone is 40 miles one way , 5 times a week. but your response does put my mind at ease. i appreciate all your help.
P.S.- I also keep an extra qt. of oil in my car...
1_MEANZ28
08-07-2012, 02:58 PM
good thread filled with wise members,i believe ur ls1 is good.my dd ls1 has 236k and counting,dosent seem to consume oil,(i will check today),finishing doing full bolt ons on her,have beaten other helthy ls1's with 60k miles,so i know its not underpowered.these ls1 motors are very good....in the procces of doing h/c/i...:)
kernandl
08-08-2012, 07:54 AM
I have to agree with you on that. durability is amazing! I've put mine through the ringer and never had to replace anything internally. the only parts that failed on my car was the rear-end , tranny , and plastic interior pieces that were exposed to too much sun. (mostly my fault) i constantly rave to friends about the wise purchase I made with this car!!
