Intercooler?
Intercooler?
How would one build an intercooler for a custom roots blower? Going to build something like this https://ls1tech.com/forums/forced-in...y-ls1-bmw.html
that looks familiar. =)
If you have the room, a heat exchanger isnt a big deal. Make the lower intake large enough to fit whatever heat exchanger you want to use and mount it inside under the blower outlet. If you have the ability to make this set up, you can easily come up with a plan on the exchanger.
Also, take it from me, use your time and go a different route. I am already over this setup. 9psi and under 450whp spraying meth is not a great setup. These blowers are terribly inefficient. I will hopefully ditch this setup this winter and find somewhere to cram a TC76.
